on 24-08-2024 05:32 PM
Our broadband went done and since then our Hive devices Hub and also Thermostat are showing as offline on the Hive App. We have tried everything to get it back working, unplugging and following the Hive help videos but nothing has helped. The Hive box from the router has a green solid light and also the receiver from the boiler.
Has anyone got any ideas of how to resolve this please or who to contact?
thank you
on 25-09-2024 06:45 AM
Thanks for the update.
on 24-09-2024 05:14 PM
That is good news.
on 24-09-2024 04:57 PM
After contacting Hive they sent us a new Hive Hub and cables and this has resolved the issue.
on 28-08-2024 07:26 AM
Hi doris,
Thanks for the update and please let us know how you get on.
on 27-08-2024 08:52 PM
Let us know how you get on please.
@Michelle-TalkTalk may have some other thoughts that may help.
on 27-08-2024 08:39 PM
Thanks for your help, I have just emailed Hive to see if they can help with the issue.
on 27-08-2024 06:59 PM
I've had a look at the internet and find this seems to be quite common with some saying the Hive Hub may be faulty.
Others recommend turning the Hive off for half an hour and trying again.
Some seem to suggest it needs to connect to the 2.4ghz channel depending on model number.
If this is the case go into the router settings and turn off 5ghz temporarily and try again. If you connect, you can the reinstate 5ghz.
It is probably an issue with the hive rather than router if other devices connect ok, so as I suggested, it may be worth posting on the hive forum, detailing your model number, for help in reconnecting if the above suggestions do not work
on 27-08-2024 06:42 PM
I’ve reset the router with a pin snd unplugged the Hive Ethernet cable and reconnected and this hasn’t worked. The Hive is showing a solid green light.
on 27-08-2024 06:45 AM
Thanks for confirming. Have you tried factory resetting the router and then re-setting the router back up again?
on 26-08-2024 05:52 PM
Hi it’s only affecting the Hive, everything else is working. We’ve tried rebooting the router, I really don’t know what to do next, thanks
on 26-08-2024 08:24 AM
Hi @doris67
Are all other devices connecting ok? Is this only affecting Hive?
on 24-08-2024 05:44 PM
Maybe consult the Hive Forum for help?
https://community.hivehome.com/s/
of you haven't done so, maybe reboot the router and try the hive set-up again
