How to improve my speed
longman
Message 36 of 36
Disclaimer - I don't know very much about this sort of stuff !!!
A couple of months ago I upgraded to full fibre150. Installed with Eero6. The speeds I am regularly obtaining are around 40mbs on both my desktop and my phone. Previously I was on the talktlak hub which was hard wired to the desktop and has the full 32mbs that i was paying for. I installed a wifi card in the desktop, I paid about £55 for it so I guess it should be  a decent one and that is how it is now.
If I take my phone and stand near the Eero and do a speed test I get 150mbs no problem so I am thinking it is a coverage issue. The thing is, the Eero is only about 6 metres from the PC's wifi antennae and although in a different room there is only a hallway in-between the two. Can it be that I need another Eero ? at not insubstantial cost. Surely I should get full coverage for this small area or are they just pretty poor coverage despite being sold something that is supposed to be all singing all dancing. I feel I have been sold a pup by talktalk.
35 REPLIES 35
Message 21 of 36
I've raised this back now. Can I just confirm, what channel is it on now? Will it let you manually change the channel?
Message 22 of 36
Hi, it does not seem to be much different than before. it is a little intermittent. occasionally I am getting the full speed but more often than not I am not getting anywhere near it.
Message 23 of 36
Good morning,
Our team have advised that this should now be resolved. Would you mind retesting please and letting us know how you get on?
Message 24 of 36
Good morning,
Thanks @KeithFrench.
I've raised this over to our Devices Manager to apply the fix and will post back to confirm once this is resolved.
Message 25 of 36
A quick question for you, bearing in mind that the Eero is the only TalkTalk-provided router that I have never had, I have to rely on screenshots from customers like yourself, to try & understand the app. In the two screenshots (thanks for these), the first one does not show the channel numbers, but the second one does. What did you have to do to get the two different screenshots?
Now to your problem, you are stuck on the 2.4GHz WiFi band, because the Eero is using channel 155, which is not supported by the vast majority of WiFi adapters. Eero does not permit users to change their channel allocation via the app, which personally I think is a shame. This is becoming a growing problem, we have got at least two cases resolved by the Eero support team (not TalkTalk) issuing an upgrade that moves the channel down from 155 to the 36 - 48 range, which ensures the greatest compatibility with devices. However, this upgrade would seem to be only available to specific customers who have this problem.
I have asked one of TalkTalk's support to pick your thread up and add you to the list of customers with this problem of the Eero being stuck on channel 155.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
Message 26 of 36
I downloaded those. The Win10 one came up and said. Newer version already installed.
The 5HZ.
  Thank you again for taking the trouble to help.
Message 27 of 36
These are the latest drivers, one each for WiFi & Bluetooth:-
https://www.intel.com/content/www/us/en/download/18649/intel-wireless-bluetooth-for-windows-10-and-w...
To find the 5GHz channel, in the app:-
  1. Tap on one of your eero devices to go to the eero details page
  2. Tap on ‘Wifi radios’
5GHz channel5GHz channel
Message 28 of 36
Did you just use the drivers from Windows Update or did you download the latest ones from Intel?
I definitely downloaded drivers from somewhere, I remember doing it. I followed the instructions that came with the card.
This is the card if that is any help.
TP-LINK Archer TX3000E PCIe Wireless Card
Many thanks for your continued help.
Message 29 of 36
Please can you check in the Eero App & tell me what channel the 5GHz band is currently using?
Sorry to be a bit thick, but how do I find this ?
Message 30 of 36
Sorry, here it is.
Message 31 of 36
Hi @longman
I have been thinking some more about this & I noticed that your new WiFi card uses the Intel AX200 chipset, as do many different manufacturers. I know that the later variant, the AX210 had some performance issues that Intel fixed with a new driver. However, for some reason the driver registered to Windows Update was still the old one, to resolve those problems you had to download the new driver from Intel's support site. Perhaps the AX200 has issues as well with performance in some manner? Did you just use the drivers from Windows Update or did you download the latest ones from Intel?
Message 32 of 36
Looking at your other screenshot you are only connected to the 2.4Ghz band, you will never get as fast a speed as you should get unless you are connected to the 5GHz band.
Message 33 of 36
With your screenshot of:-
netsh wlan show drivers
you have truncated the output, I need to see it all. Please can you redo it for me?
longman
Message 34 of 36
Thank you for your reply.
Here is what it shows.
Message 35 of 36
Assuming that your PC with the new WiFi card runs Windows, please can you get me the output from these two commands from the command prompt
netsh wlan show interface
