on 07-11-2023 08:41 PM
Hi, having issues to setup port forwarding on my Hub2 SG4K100174 router and getting 'something wrong has happened' error. Any idea if this is firmware version issue or something trivial I'm missing here. Thanks.
on 10-11-2023 08:47 AM
on 08-11-2023 03:21 PM
No problem, glad to help.
on 08-11-2023 03:15 PM
Hi Keith,
yes resetting to factory defaults did the trick , thanks a lot.
on 08-11-2023 09:41 AM
Can you try a factory default & also tell me what hardware revision you are on?
on 07-11-2023 10:30 PM
Thanks Keith, from the stick label at the back :
Device Ver: FAST 5464-2.T4
on 07-11-2023 10:24 PM
I have just tried this & it worked first time. Is this definitely a Hub 2 (Sagemcom 5464), could it possibly be a 5364 & if so what hardware revision is it?
on 07-11-2023 10:13 PM
I will have to test this tomorrow & get back to you.
