I don't use my landline
Marion1022
Message 14 of 14
I hardly use my landline these days, preferring to use my mobile phone for making and receiving calls.  I was just wondering if I'd still be able to access the internet if I had the landline taken out.  I have Fibre 150, but as I don't think I have it set up right, although I've tried several times without success, I'm wondering where do I go from here?
13 REPLIES 13
Message 1 of 14
If your telephone cable has and RJ11 connector rather than a standard BT connector (the type that fits into a standard telephone socket) then you don't need the adapter which I think is what you are holding in your photo. The adapter enables you to connect a telephone with a standard BT connector, to the grandstream adapter
Message 2 of 14
I've plugged the other end of the RJ11 into the back of the Grandstream and have used my landline to ring my mobile phone.  The blue icon for the phone appears to flash on and off on the Grandstream and instead of a ringing tone, it's a fast beeping sound, and my mobile phone doesn't ring out.
What goes in here? The only other cable I have in the back of the Grandstream is the blue internet cable with the other end in the back of the eero.
Message 3 of 14
Hi Marion1022,
The port on the grandstream DVA is an RJ11 (the small one) to connect a normal BT telepheone connector you'll need to use the adapter provided which I assume is the one in your photo?
Message 4 of 14
Message 5 of 14
Good morning,
Yes, I have, but it's impossible as the connections are incompatible.
Message 6 of 14
Can I just confirm, have you also tried connecting with a microfilter?
  1. Plug your phone into the microfilter
  2. Plug the microfilter into the  Phone  port (green port) located on the Grandstream adapter.
  3. Check all 3 lights are on
Message 7 of 14
Try to post photos using the camera/image icon rather than as attachments.
Message 8 of 14
Yes, I have a digital voice adapter plugged into the eero, but the cable from the phone won't fit into the adapter as it only has a small fitting.  I can't send you photos as they're the wrong format and they're too big.  Maybe I should buy a new phone?
Message 9 of 14
Message 10 of 14
Even the phone not working correctly, I have no problem connecting to the internet.  I have two Eeros, one downstairs and one in my bedroom, but I don't think the phone, the Eero in the bedroom and especially the VoIP are connected up properly.  If you look back at my previous posts, somebody suggested sending an engineer out to check that my equipment was set up correctly, but as I've been having some health issues which ended up with me going into hospital for a major operation, I haven't been able to get things sorted out.  The landline phone in my bedroom is rather useless anyway as it doesn't hold the charge.
Message 11 of 14
Hi Marion1022
You can still use the broadband service without connecting your phone.
Are you experiencing issues with using the connection?
Message 12 of 14
Yes to the first question.
I have Fibre150 VoIP.
Message 13 of 14
Hi Marion1022
Just to confirm, do you have a FTTP connection?
What package shows in My Account?
