on 30-05-2025 09:34 AM
My work provides an IKEV2 VPN for access. This works for me anywhere apart from at home using my TalkTalk connection.
I have spoken to the IT people and there is no fault at the office and the VPN is working for everyone else.
I have searched this forum and have found similar posts to mine that seem to indicate that a firmware update for the router resolves the problem. Can this be done for me please.
on 30-05-2025 09:56 AM
on 30-05-2025 09:55 AM
Yes please
on 30-05-2025 09:54 AM
You are very welcome.
on 30-05-2025 09:52 AM
Thank you so much for the support @KeithFrench
-Fez.
on 30-05-2025 09:50 AM
Hi @Miranda16
If you have the Sagemcom WiFi Hub 1 or 2, I have done extensive VPN testing on all firmware versions, including the current V208. I have found no issues at all. However, I cannot test yours as there does not seem to be any free IKEv2/IPSec VPN server addresses.
on 30-05-2025 09:37 AM
Hi there @Miranda16 , thank you for reaching out to us, just to make sure that I comprehend, you need assistance with updating your router's firmware?
-Fez.
