on 02-02-2024 12:39 AM
It is getting tiresome now.
Every single evening, around midnight my internet just disconnects. Router say it i still connected all the time,. If i am watching netflix, or playing xbox online, that all disconnects laptop and mobile disconnect also.
It then takes between 5 minutes and 4 hours for it to come back online. I have tried resetting router, which does it stuff comes back online says it is connected when it clearly isnt a nothing will connect with an internet connection.
It is just getting very tiresome now.
If it i talk talk resetting each night, why midnight, and not like 3am when less people would be using it.
25 minutes ago - last edited 23 minutes ago
@Emma90x wrote:My does the exact same thing. Every night just after midnight cuts off and usually doesn’t come back until around 5/6 hours later.
Read this thread, the customer is having the same issues and found a way of getting back online, not a fix but it'll let you use the internet while the support staff get to the bottom of your problem -
4 hours ago
Hi @Emma90x
Please can you log into My Account and check to see if HomeSafe/KidsSafe or Homework time has been switched on?
11 hours ago
My does the exact same thing. Every night just after midnight cuts off and usually doesn’t come back until around 5/6 hours later. It’s so frustrating why does it do this. I’m paying for a service that i can’t use at certain times then I shouldn’t be paying full price for it
on 24-02-2025 07:09 AM
Hi Henry,
Please can you create your own topic and we can look into this further for you.
on 24-02-2025 12:07 AM
Mine does this every Sunday at midnight it’s just done it now as we speak I think it might be to do with the servers but it’s extremely annoying
on 19-02-2025 06:36 AM
Hi @Paradyski
I'm sorry to hear this. Please can you create your own topic and we can look into this further for you.
on 18-02-2025 08:23 PM
Mine is keep cutting throughout day and night. I did restart, reset etc but still the same. I will look for another provider after 4 years with TT
on 13-01-2025 08:06 AM
Hi Paul,
12-01-2025 11:43 AM - edited 12-01-2025 11:43 AM
@PaulC31 wrote:Same here in Cardiff - it’s annoying as no notice given or explanation
Paul if you haven't already done so open a new thread the support staff will not talk to you in someone else's thread.
on 12-01-2025 10:33 AM
on 04-11-2024 02:12 PM
And it's switched off?
on 04-11-2024 01:10 PM
Yes checked it last night.
on 04-11-2024 08:21 AM
Hi Avieron,
Have you checked your HomeSafe settings?
on 04-11-2024 01:05 AM
Mine is doing the same, and has done for months. When I tried to phone them I found out that they are closed and there is no way of getting it sorted at night time. But when I phone them in the day time, they just say everything is working fine. It is because it's not midnight!
on 02-09-2024 07:14 AM
Hi Ash_a4
Thanks for confirming that this has resolved the issue.
We have seen cases where on occasions HomeSafe/Homework time has been activated in My Account. As you have correctly advised, this can be switched off again in My Account.
Thanks again.
02-09-2024 12:37 AM - edited 02-09-2024 08:12 AM
Thanks, @Ash_a4.
If you look back through this thread you'll see that this indeed is what staff ask people to check when this happens.
Interesting that you had to disconnect and reconnect.
on 02-09-2024 12:33 AM
Just incase anyone else is having this problem, I also had this problem my internet would turn off every night at 12am and I had no idea why. If you log onto your talk talk account and go to my account then scroll down to where it says my security and click onto it and then scroll down and it will say homework time and mine was set to switch the internet off at 12am every day so I switched it off and my internet came back on. Side note I had to swipe down on my phone and switch the internet off and then back on and it was fine. Hope this helps someone.
on 26-08-2024 07:17 AM
Hi Lorider50
Please can you create a new topic on the Community, we can then take a look at this for you.
on 23-08-2024 04:18 PM
It is best to start your own topic and the support team can then look into this for you.
on 23-08-2024 03:59 PM
I've just started a new contract with TalkTalk, nothing was mentioned regarding services would be cut around midnight, on a regular basis for maintenance?
