Internet cuts out every week at 12am
Muddy137
Message 20 of 20
So for the last 3 months on a night at 12am my Internet cuts out were I can't use my Internet at all but if I'm playing a game the game does not disconnect even if it's a online game, this happens for about 30 minutes or longer, I test my Internet and it say there is nothing wrong and my router is still connected and say everything is working yet like right now I have to use my mobile Internet on my phone and yes the white light is on and the router says its working but its not....
19 REPLIES 19
Message 1 of 20
Good morning,
Just checking back in to see if this has happened again since you made the changes?
Message 2 of 20
Hi Muddy137
Apologies, this may have been activated in error (system error)
Message 3 of 20
yep i hope it was, but i dont see why it was even on as i never picked it too be on and it only doing on sunday/monday morning but not the rest of the week.
Message 4 of 20
Good morning,
Thanks for the update. I think this may be the issue. I'll re-check back in with you next week to see how you're getting on.
Message 5 of 20
so when i was looking at home safe it seems it had Homework Time turned on for some reason from Monday to Friday from 12am to 1am, do you think that my have been why it was doing it as it seemed to be on a Sunday/Monday morning from them time it was doing but never had it happen other day. but i turned on home safe and will turn it off again in 3/4 hours then see if it happens again on Sunday.
Message 6 of 20
I'm really sorry to hear this. Would you mind trying one more thing before we escalate this over please? Could you try switching HomeSafe on in your My Account please, then wait a few hours until this shows active and then once active then switch this off again please.
Message 7 of 20
so it happened again for 1 hour, from 12am till 1a, just like before said i had internet but i didn't
Message 8 of 20
Hi Muddy137
That's great. I will check in again with you next week to see how the connection has been with the new router connected.
Message 9 of 20
so i got it and ill reply here if it still doing it.
Message 10 of 20
Hi Muddy137
I've ordered a replacement router for testing, please allow 24-48hrs for this to arrive.
Message 11 of 20
Yes that will be when it happened and I did reset the router too see if that helped but it didn't so I just left it and it turned on again about 1am or so. And no I don't have another router to test, and I all so ran the tests when it happens and it say the same that its all working.
Message 12 of 20
Thank you. I've run a few tests and checked the connection stats and everything looks ok from here. I can see 2 re-connections on the line. One on 14/04 and another on 21/04. Is this when it last happened and you rebooted the router?
Do you know if any of your devices run any updates or back ups around this time? Do you have an alternative router that you can test with? If not then I think we should send one for testing purposes to rule this out.
Message 13 of 20
OK done.
Message 14 of 20
  • Name
  • Telephone number
  • Alternative contact number
Message 15 of 20
Yep I did and no its not on, as I said this happens once a week at 12am but not on the same day each time, were the Internet will not work but if I'm all ready watching a film or playing a online game I don't get discounted but if I close them it will not work again.
Message 16 of 20
Hi Muddy137
There is a settings in KidsSafe which often is enabled (sometimes in error by the system) and this can stop the connection working at certain times.
Did you log in just to check this? As mentioned this can be a system issue.
Message 17 of 20
Nope it's not on and never has been on as I have no kids and i don't see how that will make my Internet cut out once a week 12am
Message 18 of 20
Hi Muddy137
Please can you log into My Account and check to see if HomeSafe/KidsSafe has been switched on?
Muddy137
Message 19 of 20
So just over a hour now off my Internet not working, reset router, tested Internet, reset router again, reset router for 20 minutes and all still not working but if I'm all ready watching something that video will play to the end and then stop working saying I have no Internet.......
