09-09-2024 07:46 PM - edited 09-09-2024 07:47 PM
Since having fibre 150 we have suffered from the occasional dropouts.
This last weekend we have noticed more and more with the message no internet connection whilst surfing.
These don't last very long but are annoying when they occur.
All devices are connected to the Eero by WiFi.
Is it possible to check my line for errors please?
on 11-09-2024 08:05 AM
Will do @Michelle-TalkTalk
on 11-09-2024 07:55 AM
Morning @fr8ys
Ok thanks for confirming. I'll keep my fingers crossed. Any change then please let me know.
Michelle 🙂
on 11-09-2024 07:54 AM
One drop out to my tablet noticed and again no ! next to the icon.
I'll continue to monitor in case that was an issue with the TalkTalk forum website just being slow to respond as that was the message this time not no Internet.
on 11-09-2024 07:04 AM
on 10-09-2024 11:57 AM
Great thank you. If there is no change then I think we should replace the eero.
Michelle 🙂
on 10-09-2024 11:56 AM
Just checked and an update was pending so I've initiated it now.
Will monitor and let you know.
on 10-09-2024 11:52 AM
Sorry for the delay. Does the eero have the latest version of firmware in the eero settings? If not then I think it would be worth updating this just to see how the connection compares? If it does have the latest version then I think we should replace the eero, would this be ok?
on 10-09-2024 11:30 AM
@Michelle-TalkTalk it went again at 11:01. I checked the ONT box and all lights were on.
One thing I did notice was the wifi on the affected devices (it didn't happen to all) the signal went from the usual 4 bars to 2, but still showing a signal and no ! next to it to signify there was no internet. The browsers just had trouble connecting and then the message no internet check your settings appears.
on 10-09-2024 10:04 AM
Not noticed the lights and it re-connects pretty quickly every time, certainly less than a minute.
on 10-09-2024 10:00 AM
Thanks for confirming. Have you noticed if any of the lights change on the ONT when this happens?
Does it re-connect on its own or do you have to reboot the eero?
on 10-09-2024 09:55 AM
It's on various devices and the PC is in the same room.
We have a bungalow so coverage is good and normally a full signal to all rooms.
Just the one Eero.
on 10-09-2024 09:43 AM - last edited on 10-09-2024 09:52 AM by fr8ys
Thank you 🙂 I've run a test on the line now which is clear and I also can't see any re-connections on the line. Does it seem to happen to certain devices only (devices further away from the eero) How many eeros do you currently have?
on 10-09-2024 09:09 AM
Doh! Done now.
on 10-09-2024 08:32 AM
Morning @fr8ys
No problem. Could you add your Account number to your Community Profile please.
Michelle 🙂
