Line upgrade to Full Fibre - Installation Issues
Caalon
Message 8 of 8
Hi There,
Recently i have made decision to upgrade my broadband to FTTP 900 variant, as my VDSL deal is coming to end and this just became available.
Today (04/03/24) MJQuinn on behalf of Openreach came and performed installation (all wiring including of fitting of ONT has been done), however they could not connect to Openreach network (PON light solid red), and they left saying to contact TalkTalk as Openreach engineer need to come and investigate fault.
I have been then in touch with Support, however they cannot give any updates, as there is nothing on their system to support this issue.
Is there anything i can do? How long normally does it take to have issue like that resolved?
7 REPLIES 7
Message 1 of 8
Brilliant, thanks for letting me know 🙂
Message 2 of 8
Hi Chris,
Thanks!
This now seem to be working fine, that's case closed now then 🙂
Best regards
Message 3 of 8
Hi Caalon,
That's great news. Regarding the voice service, I would give it a couple of hours and if it's then still not working please let me know and I'll look into it further
Message 4 of 8
Hi Chris,
Openreach engineer turned up today to rectify fault, apparently it was bad splice 2 roads down that was preventing connection.
This is up and running now.
On the other hand, since now this is completed, how long will it take for Digital Voice Adapter to come online?
Best regards
Message 5 of 8
No there's no time scale but I'll keep an eye on it and let you know when there's an update
Message 6 of 8
Hi Chris,
Thanks for that, please keep me posted.
Did they provided you with any timescale?
Best regards
Chris-TalkTalk
Message 7 of 8
Hi Caalon,
This is still in hand with Openreach, we should hopefully have an update later today so I'll check again this afternoon
