on 31-12-2023 06:22 PM
Had full fibre 65 for 3 years with lovely connection (about 65mbps on ookla). Last week download speed dropped to 10mbps initially and is currently at 3-5mbps (says on your speed check I should get at least 40mbps). Contacted talk talk and they have sent another router (due on the 2nd Jan).
I’m using an ASUS AC-3200 router with a modem attached - I’ll be honest, I don’t know much about the setup as my brother did it for me. Tried rebooting and factory resetting the ASUS router with no luck so I wired up a friends spare talk talk router and experience the same speeds but with intermittent connection loss). ASUS router holds a stable connection so I’ve shifted back to using that temporarily.
When I go online the connection checker tells me I’m getting 58mbps down the line at the moment but says there’s an issue with my router and device connection (this happens with both routers).
How can I go about getting a visit from an engineer as I’m confident there is something wrong here beyond my reach and knowledge?! Unless someone can think of another step I could try?
Apologies to you poor souls who read this as I’ve had copious amounts of caffeine today trying to fix it and am at whits end! TIA!
on 05-01-2024 08:17 AM
Hi ElDaSloth
How are you getting on following the engineer visit?
on 02-01-2024 01:50 PM
Hi ElDaSloth
Thank you 🙂
on 02-01-2024 01:49 PM
Lovely - thank you Debbie will keep you updated
on 02-01-2024 01:48 PM
Hi ElDaSloth
I have arranged the engineer visit for 04/01 AM (8am - 1pm)
on 02-01-2024 01:36 PM
Yes please. I’ll be here everyday except Friday PM
on 02-01-2024 01:28 PM
Hi ElDaSloth
Would you like me to book the first available visit this week AM and PM? Are there any days you are not free?
on 02-01-2024 11:46 AM
Yes please. Can you give any indication of when it might be as I’m off work until next Monday and will need to make sure someone’s here if it’s after that?
Thought I’d add this too as unsure if it will change anything?
I’ve noticed that one of the poles by our house looks as if it is falling over - it’s also the one my line is connected to I believe (see picture). I’ve also highlighted bits where the line seems to be resting on other cables between my house and the pole.
on 02-01-2024 10:59 AM
Hi ElDaSloth
Would you like me to arrange an Openreach engineer visit?
on 02-01-2024 09:43 AM
Yup - already stated in the posts I’ve tested with a different router and all still connected.
The resets you can see I was told to do by Mary on your online support. Aware they can affect line speed but I’m currently getting 2mbps which is well below my guaranteed 40mbps.
on 02-01-2024 09:31 AM
Hi ElDaSloth
The line test is clear - No faults detected ,but I can see re connections on the line and this will affect the sync speed.
Is the router at the test socket at the moment? Have you tested with a different router?
on 01-01-2024 01:06 PM
Done - thank you Keith!
on 01-01-2024 09:59 AM
As the light goes orange, the connection is unstable for some reason. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
on 01-01-2024 01:10 AM
Under my package in account is just says Fibre 65.
My brother ordered me the open reach modem - I’m not 100% sure how it’s setup so I’ll double check with him.
Assuming because it has been working for 3 years flawlessly that it’s the correct bit of kit?
on 31-12-2023 11:28 PM
You mention an Openreach modem. Which service do you have, exactly? Because Full Fibre would require an ONT rather than a modem. Whereas so-called Fast Fibre will work with an integrated modem/router.
on 31-12-2023 11:06 PM
Sorry forgot the rest! I’ve only got one device wired up and it’s my main desktop.
Wired up with CAT-6 cables but only gets about 3mbps download.
Have tried swapping wires both from desktop to router and from the open reach modem to the router.
on 31-12-2023 11:03 PM
Hi Keith,
Thanks for the reply!
When connecting the talk talk router I get the same speeds in the initial dashboard although the upload speed is a bit stronger.
When the intermittent disconnecting happens it shows an orange flashing light on the front
on 31-12-2023 10:11 PM
When using a TalkTalk router, what speeds does this display when logging into it (normally in the initial dashboard area)? When you get an intermittent connection loss what happens to the light on the front of the TalkTalk router?
Is this just wirelessly connected devices that give slow speed test results, or does it also affect wired (Ethernet) connections as well, if you have any?
