No external IP address eero 6
Hugh_hogwash
Message 5 of 5
I got full fibre on 8th March and there were some issues connecting us to the Internet. After a week it started working and has been fine until yesterday when the Internet cut out. Now when I try and connect the eero to the Internet it says no external ip address. I've been on the online chat but no one seems to know what the issue is! I don't have a device that I can connect directly with an ethernet cable either to test if its the eero.
4 REPLIES 4
Message 1 of 5
Hi Hugh,
I'm showing a connection here, did you get this sorted, or do you need assistance ?
Message 2 of 5
Thanks for that, it sounds like it might be a TalkTalk issue. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
Hugh_hogwash
Message 3 of 5
Yes, I've turned it off for 30 mins and tried again. There are 3 lights on the ONT.
Message 4 of 5
Have you tried turning the Eero off for at least 30 mins & trying again? What lights are on the ONT?
