No fibre connection - Please help!
Danniiw001
Message 17 of 17
Hoping someone can help as I am at the end of my tether.
A brief rundown of my issues.
Cityfibre installed fibre 23rd May.
No fibre connection at all, old broadband line still working for 3 days.
Spoke to multiple agents - told hadn't been activated so they would activate. Still no luck.
Further agent ran tests and managed to get the fibre connected for 24hours - speeds as expected.
No fibre connection after this time.
Engineer comes, checks all connections, changes to a brand new router and cable and still same issue.
All 4 green lights showing on the black fibre box on wall.
Further phone calls and told today that the order management team hasn't finalised activating the account even though it has been 10 days. Told to just 'wait it out'. I honestly don't know what else I can do. I have spoken to well over 12 agents, various different departments including the fttp team and no one has fixed my issue. Husband and I both wfh and we are 10 days without a connection now and no end in sight.
Please help!
16 REPLIES 16
Message 1 of 17
I'm glad to hear that this has now been resolved. I'm sorry that this took so long and that it wasn't resolved in the first instance for you.
Danniiw001
Message 2 of 17
Just to confirm that after 3 weeks, 20 agents, 1 engineer visit, 2 different routers and 1 formal complaint this has now been resolved. Apparently it was due to a 'misconfiguration' setting which had been missed off but has now been fixed. Thanks all
Message 3 of 17
Thank you 🙂
Message 4 of 17
Ok 🙂
Message 5 of 17
If you would like us to look into your connection for you then please can you create your own topic and we'd be happy to take a look.
TerranceKnudsen
Message 6 of 17
Have you resolved it?
Message 7 of 17
The team have advised that they will be making contact with you directly.
Message 8 of 17
Thanks for confirming. I've escalated this over to our Faults Escalation Team and will let you know as soon as we receive an update back. It's possible that the team may also try and contact you directly.
Message 9 of 17
Hi Chris,
There isn't a label on the router but I believe it is the wifi hub 5364. I have now been sent a brand new router that I was told would 'definitely' fix the issue but this has made absolutely no difference. I have an open complaint so I will have to contact them yet again as still no fibre.
Message 10 of 17
could you just take a look at the label on the router and let me know what the model number is
Message 11 of 17
Hi Chris,
It is the standard wifi hub. Just to confirm as well that the engineer tested with a brand new router and still the same issue.
Message 12 of 17
OK thanks, which router do you have?
Message 13 of 17
Yes Chris, still without service. Coming up to 2 weeks tomorrow.
Message 14 of 17
Hi Danniiw001,
Just to confirm, do you still have no service?
Message 15 of 17
Thank you, much appreciated.
Gliwmaeden2
Message 16 of 17
Staff will be back on Monday, @Danniiw001. Am making sure that this is in the queue for attention.
