No lights on router
nishilt
Message 7 of 7
Randomly and all of a sudden my internet cut out. Check the router and there are no lights. None, no white and no orange. I switched the plug - still nothing. I called customer service, who said it is not a router problem. But a problem with my line. And engineer will need to be sent out.
Which seems strange. If it is not a problem with my router. Why are there NO lights?! And if my router is working fine, why am I no able to find it on my laptop or phone?
6 REPLIES 6
Message 1 of 7
Hi @nishilt
Please can you only add personal information to your Community Profile.
Message 2 of 7
REMOVED
Message 3 of 7
Hi nishilt
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 4 of 7
Hi @nishilt thanks for checking, unfortunately I don't have fibre so honestly don't know.
Have you another router you could try, and is the ont working ok?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
Message 5 of 7
Unfortunately I do not have one. Is there another way I am able to check?
Is the problem possible though. Can the router still be working with no lights on? Surely you would expect to be the orange light is there is a problem with the line??
Divsec
Message 6 of 7
Hi @nishilt if you still have one is your landline phone working? Your post has been escalated and you should hear tomorrow when the team are back at work.
