Port Forwarding on Sagemcom 5464
trisgti
Message 3 of 3
Hardware Version = FAST5464 2.00
Software Version = SG4K100174
hi, I'm moving over to the TT-supplied router and trying to get my Nextcloud service working.
DDNS is set up, and I think I have 80 and 443 port forwarding set up correctly but I cannot hit the internal server via the DDNS URL (but can hit it using internal server ip address)
was working fine on previous router, nothing has changed in the internal setup other than router swap.
protocol = TCP
external host = *
internal host = ip of nextcloud server
external port = 80
internal port = 80
protocol = TCP
external host = *
external port = 443
internal port = 443
is there anything obvious I'm missing?  thanks
Message 1 of 3
Hi @trisgti
@Anonymous has asked me to help you with this issue. Please can you confirm:-
  1. What operating system & version is hosting this web server?
  2. Have you allowed the ports through any PC firewalls?
  3. How are you testing this, via a port-checking website or trying to connect from a device locally connected to the router, via your DDNS domain name?
If the latter, this will never work, due to NAT Loopback. Any traffic from the local network, that goes out to the internet & back in again is blocked by the router, as it believes it is a security vulnerability. The best way to test like this is to disconnect a smartphone from the router's WiFi & use mobile data.
Message 2 of 3
@KeithFrench - would you be able to offer any advice please?
