Request for Improved Wi-Fi Coverage
Ranjan94
Message 3 of 3
Message 1 of 3
How are you getting on?
Message 2 of 3
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
Do you have any wired connections & if so, how do they perform?
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
