on 31-12-2024 11:33 AM
Hello my router is blocking my work VPN so I am unable to work from home. I have recently moved house and I am using the same router as before. I had previous problems with this in my old address but this was resolved. Perhaps the firmware needs to be updated? It is very important I am able to connect to my work VPN in order for me to work. Please help.
on 10-01-2025 07:04 AM
Hi @Haylzzx
I'm so glad to hear that everything is working ok now. Did your IT department advise what was causing the issue?
on 09-01-2025 11:09 PM
Hi Debbie,
I received the router and ruled out that is not the issue thank you so much for trying.
my I.T department have managed to rectify the issue finally.
i will post the new router back to you tomorrow.
on 09-01-2025 08:39 AM
on 06-01-2025 01:10 PM
Hi @Haylzzx
I do appreciate your frustration, but please don't take it out on me. Your case is one reason why I give up a lot of my own free time, unpaid, to try & help you & other customers. I have a high level of IP networking skills, which I use to try & help any TalkTalk customer. As I mentioned I did a lot of pre-launch testing to help TalkTalk out before firmware V206 was put on general release.
on 06-01-2025 12:27 PM
Hi @Haylzzx
Let us know how you get on.
on 06-01-2025 12:07 PM
Yes please thank you Debbie
on 06-01-2025 12:03 PM
Hi @Haylzzx
Would you like me to send a replacement router so we can rule this out?
on 06-01-2025 12:00 PM
Thank you Keith, just getting really frustrated at this situation. My I.T department are clueless so I am not getting any help from either ends. I can’t work it out.
the log in also doesnt work on my hotspot or a router that i bought tp link sim card one. Cant work it out.
on 06-01-2025 11:58 AM
Hi Debbie yes. I have powered down the router for 30 mins. I have also tried wire and wirelessly connecting and logging in but still no joy.
i haven’t had a router sent out for testing. I had this issue in 2020 in my old house and was sent a router which fixed the issue now I have moved house I used the same router and equipment as before but have the issue. The only thing that has changed is my house address.
on 06-01-2025 11:57 AM
Hi @Haylzzx
@KeithFrench KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue. Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others. If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc. one of the TalkTalk team will jump in and help out.
on 06-01-2025 11:55 AM
How is my comment rude @Haylzzx ?
There was not anything obvious for a Windows version of your VPN Client on the Pinnacle website. I am simply trying to help you here, I have tested the PPTP VPN protocol already for you & which worked both when I did initial firmware testing prior to the launch of V206 and again as a favour to you the other day and in both tests it worked perfectly.
Yes, it is true that I do not work for TalkTalk, but I work with them extensively.
For your information:-
on 06-01-2025 11:54 AM
Hi @Haylzzx
Just to confirm, you have tried powering down the router for a full 30 minutes?
Have you tried connecting wired to the device using the VPN client?
Have we recently sent you a router for testing?
on 06-01-2025 11:49 AM
I am merely an employee of a company i dont know how you expect me to have a link to a vpn? I don’t work for their it department nor do i know anything about vpns. I pay for a service i expect to receive. Not have rude comments being written by someone who doesnt even work for talktalk
on 06-01-2025 11:42 AM
Hi @Haylzzx
As I asked the other day, is there a download link for a Windows version download for your VPN client, so that I can test it?
on 06-01-2025 11:40 AM
Hi Debbie
yes i still have the issue
my it department havent made any suggestions i cant work out what it is that is causing this
on 06-01-2025 09:58 AM
Thanks @KeithFrench
Hi @Haylzzx
Are you still experiencing this issue? Have your IT department made any further suggestions?
on 06-01-2025 09:26 AM
No, I haven't been able to test this actual VPN client, as their website doesn't give any download links for a Windows version, even though @Haylzzx is using that one. I did ask the customer if there was a way I could download it, but I have not yet heard anything. I originally tested the PPTP VPN protocol when I did the V206 testing & that was fine, I retested it in response to this problem & it still works fine.
on 06-01-2025 09:10 AM
on 05-01-2025 01:37 PM
@Haylzzx, I'll re-escalate this thread and remove your duplicate.
Staff are not on here at weekends, and so you haven't heard from staff since completing your details.
Please don't start new threads for the same issue.
on 03-01-2025 03:04 PM
Hi @Haylzzx
I couldn't find a download link, please can you give me the link? If it is free, then I will test this client, rather than just using another one that uses PPTP.
