Router
Wadders11
Message 3 of 3
Router is a TalkTalk6B4A22 and keeps losing internet connections within the house. My computer was on wireless but I changed it to hard wire and that now works all the time but my other devices like I phone and my wifes laptop which are wireless still lose connection, this happens regularly sometimes twice a day. Seems it is not sending any signal out into the house. Is it faulty
Message 1 of 3
Thanks @KeithFrench
Hi Wadders11
I can see that Keith has offered to help.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
@Wadders11 If you add your name and TalkTalk landline number to your Community Profile, I can then check which router you have.
Message 2 of 3
Hi @Wadders11
That is not the router make & model, but the wireless network name. If it is the router I think it will be, there will be a label behind a removable plastic panel that will identify the router. It could be a Sagemcom 5364 or 5464, an Huawei DG8041W or an Amazon Eero.
