Problems with service
Kestrel10
Message 10 of 10
I am having real issues with the reliability of my TalkTalk service. I have rebooted the router, but this has not helped. Loading webpages takes an age and when trying to stream video content this is nearly impossible, as it stops and starts during playback. I never used to have this problem.
A line check has been run and everything is meant to be OK.
Trying to download a small file takes a long time too.
Not sure if the router is running the latest firmware or if it requires changing.
Please advise.
9 REPLIES 9
Message 1 of 10
Hi @Kestrel10
That's great news, thanks for letting me know 🙂
Message 2 of 10
Hi Debbie,
Many thanks for sending the new router. It arrived on Friday and I set it up Saturday. Once I got all my devices connected up and tested the connection it appears to be back to how it should be.
I will package up the old router and return it this week.
Many thanks for your support and help with this issue.
Kind regards
kestrel10
Message 3 of 10
Message 4 of 10
Hi Debbie,
That's fantastic.
I will update once I have tested the replacement router.
KESTREL10
Message 5 of 10
Hi @Kestrel10
Thanks for your reply 🙂
Let us know how the connection compares with the new router.
Message 6 of 10
Hi Debbie,
It would be great if you could send me a new router.
Hopefully this will sort out my issues.
Many thanks
Kestrel10
Message 7 of 10
Hi @Kestrel10
The line tests are clear but I can see that you are using one of our older routers. Are you happy for me to send a replacement router?
Message 8 of 10
Thank you. I have now updated my profile.
Message 9 of 10
If you would like the support team to look into this for you make sure that your personal details including TalkTalk phone number or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
