Sagemcom 5464 not connecting
on 30-04-2024 12:57 PM
Message 7 of 7
On Fibre 65 Data Only with telephone vis copper wire.
Sagemcom Fast 5464 wifi began not allowing connecting to smartphone. I tried resetting router which solved issue for short time but after further problems and resets the router is not connecting to fibre Service at all. Amber light keeps flashing.
Found old Sagecom Fast 5364 router in cupboard and it connects to Fibre Service OK and wifi is working correctly.
Looks like I need a new 5464 router. How do I go about requesting one?
Thanks for any help
Ron
Labels:
- Labels:
Connection
Router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
6 REPLIES 6
on 01-05-2024 10:11 AM
Message 1 of 7
OK Thanks for info.
Ron
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-05-2024 06:11 AM
Message 2 of 7
Yes, we can provide the 5464 if required. Also if you ever upgraded to a faster Full Fibre package you would be provided with one or more (depending on package) eero routers instead of the sagemcom.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-04-2024 04:25 PM
Message 3 of 7
Hi Chris
I assume I will have to switch the telephone to VOIP sometime soon. When this happens will a new 5464 router be provided?
Ron
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-04-2024 02:31 PM
Message 4 of 7
Hi Ron,
If you're on data only the 5364 should work fine, the only difference between the two routers is the 5464 has a port for a telephone for if you have service with VoIP
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-04-2024 02:11 PM
Message 5 of 7
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-04-2024 01:28 PM
Message 6 of 7
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
