Speed
sharky110
Super Duper Contributor
Message 15 of 15
@debbie talktalk@ hi my download speeds upstairs are crap I am getting  less than 10 download speed I am on future fibre 65  can anyone help pleas
Kieran
14 REPLIES 14
Message 1 of 15
sharky110
Message 2 of 15
@Anonymous  thanks I will do
Kieran
Message 3 of 15
Ok thanks for confirming, I'd recommend Live Chatting the Future Fibre Team directly as they will be able to run through some checks with you and confirm if an additional eero is required.
Guide to Full Fibre and FTTP | TalkTalk
sharky110
Message 4 of 15
@Anonymous  only got one eero it can happen in the kitchen sometimes but mostly upstairs yes it is in a optimal position
Kieran
Message 5 of 15
Ok thanks for confirming. How many eeros do you have? How far is the wireless device from the eero? Is the eero set up in an optimal location and not located too close to any electrical devices? Is it also all wireless devices affected?
sharky110
Message 6 of 15
@Anonymous it seems to be wireless connections I am on Erro 6  fibre 65  but I was told  I would get excellent wireless connection especially  upstairs
Kieran
Message 7 of 15
Thanks for the update. Can I just confirm, do any of the lights change on the router or the ONT when the connection is dropping out? Does this happen on all devices?
sharky110
Message 8 of 15
@Anonymous  they were OK last night not checked speed this morning but I am loosing connection had to ha three attempts to connect to this chat
Kieran
Message 9 of 15
How are you getting on?
sharky110
Message 10 of 15
Ok will do
Kieran
Message 11 of 15
Hi sharky,
Could you switch the router and ONT off and leave them off for at least 30 minutes, then switch back on and retest - please let us know how you get on
sharky110
Message 12 of 15
@Debbie-TalkTalk yes wired and wireless I am using a euro 6 on future  fibre 65
Kieran
Message 13 of 15
Hi sharky110
Is this the speed you are receiving on a wired speed test?
Message 14 of 15
2. If you have a wired device, such as a PC or laptop, what speed do you get from a speed test site, if you connect it directly in place of the router?
3. If you have any wired connections, are they affected in the same way as wireless ones?
