on 09-10-2025 02:52 PM
can someone please take ownership of this issue and help. My fibre 150 contract ended in August, when I contacted the loyalty team and agreed to upgrade to fibre 500. It is now five weeks since the agreed update and new contract and I’m still on fibre 150 speeds even though my account page says I’m on Fibre 500.
i have made several long phone calls to the so called order management and full fibre teams and spent many hours on chat with so called specialists, I have been transferred from department to to department until I began to loose the will to live. I have received several emails that give a go live date all of which arrived and went without change.
I find it absolutely unbelievable that a simple change of speed should take five weeks.
I have requested to speak to a person based in the UK and been told this can’t be done. So this is my last attempt to get this order sorted before I leave talktalk and go to a provider that values its long term customers.
Hopefully there is some monitoring these post that can actually do the job that there employed to do and take pride in their work
on 09-10-2025 06:09 PM
Ok, Let me speak to a contact that I have within TalkTalk. You will not be able to see my communication with her, but hopefully there Will be some progress by later tomorrow.
on 09-10-2025 04:22 PM
Hi @KeithFrench
ONT turned off left for 30 minutes turned back on unfortunately not change, speed test run via the eero app which still reports 148mbps
on 09-10-2025 03:16 PM
Hi @ricksmith
Let me know the outcome.
on 09-10-2025 03:14 PM
Hi @KeithFrench
No i haven’t tried turning off the ONT or been advised to do so by the tech support team. They did however run a speed and connection test and confirmed my speed to be 148mbps. They offered no other assistance
i will try your suggestion
on 09-10-2025 03:02 PM
HI @ricksmith
Since the upgrade, have you turned the ONT off for at least 30 mins? This is required to clear any old sessions & pick up the new speed. Once done, have you tried connecting a wired (Ethernet) device, such as a laptop, directly to the ONT in place of the router and do a speed test from there?
