on 13-02-2023 07:50 PM
I was contacted by TalkTalk to upgrade to full fibre. This was installed today but since then I've had no internet. The router is flashing red and the old connection no longer works.
Both my wife and I work from home so this is impacting us greatly. The letter indicated this would be seemless but it has been far from that.
Should the switch off of copper and on of fibre not be sequential so there's no loss of service?
I'm assuming the old router is compatible as we didn't receive a new one from CityFibre.
on 16-02-2023 06:54 AM
I'm glad to hear this and thanks for keeping us updated 🙂
on 15-02-2023 07:54 PM
The internet has now started working. Not sure if it's through this chat or the numerous complaints to the online chat, but it's now sorted. Thank you if you assisted 🙂
on 15-02-2023 02:00 PM
It doesn't say anything on it. I believe it's the Sagemcom 5364 from googling it. I've attached a picture if it helps.
on 15-02-2023 01:24 PM
Thanks for that, could you just let me know the make and model of your router?
on 15-02-2023 12:28 PM
Many thanks. I've updated the address in the private notes section.
on 15-02-2023 12:13 PM
OK thanks, could you add your address to the private notes section of your community profile and we'll take a look at this for you
on 15-02-2023 12:07 PM
Hi Chris,
The service was installed by CityFibre. We've spoken to them and they've confirmed that there is nothing left to complete on their side.
on 15-02-2023 10:55 AM
Hi keff77,
Could I just ask, was your service installed by Openreach or City Fibre?
on 14-02-2023 10:17 PM
Ok down to TT to resolve this one then.
on 14-02-2023 10:07 PM
I have checked the set up and it's all as per the instructions.
I'm not getting a signal on the laptop using the ethernet straight in to the ONT.
14-02-2023 06:17 PM - edited 14-02-2023 06:33 PM
Ok that’s the same as mine and looks good.
Router is fine. Have you plugged the Ethernet from the ONT in to the WAN port of the Hub. If in doubt follow the instructions here
https://community.talktalk.co.uk/t5/Articles/Set-up-your-Wi-Fi-Hub-2/ta-p/2791386
If still not working can you plug a laptop straight in to the ONT and see if you get a connection.
on 14-02-2023 05:37 PM
All four lights are green on the ONT. I've attached pictures to see if it helps identify the model and error.
13-02-2023 08:48 PM - edited 13-02-2023 08:52 PM
What lights are on your ONT. Post a photograph of it as there are many variations.The ONT is not your router, just to be sure there is no confusion.
Also what is the model of router you have.
If all lights on the ONT are not green, try powering off the ONT and your router for 30 mins. Then power on you ONT, wait for all green lights then power on your router.
