Using non-TalkTalk router
briduser
Message 3 of 3
Hi all,
Unfortunately it looks like it's possible that my TalkTalk router will not arrive before the installation (Yodel is showing it is "delayed, please check back".
Am I still able to use my own router like in the old days?
I have a fibre compatible router that I could use temporarily,   will I be able to use that?
Thanks in advance for any replies.
briduser
Message 1 of 3
Thanks for the reply.
Looks like we should be ok then.
Message 2 of 3
Yes. Please see info here
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
