04-10-2023 02:32 PM - edited 04-10-2023 04:21 PM
My wife works from home for NHS her laptop bring up a java applet for a VDI Client login, when she tries it while connected to a mobile hotspot it's fine, on wi-fi or ethernet it doesn't. Is there anything blocking VPN or VDI Client on my service?
I'm on Future Fibre. Thanks.
Andy.
on 05-12-2023 12:55 PM
I'll pass this to our network team. I'll let you know when I receive an update or they may contact your directly
on 04-12-2023 04:21 PM
I'm not sure. I do know that none of her colleagues are with TalkTalk and they do not have this issue. Is there any chance we can raise an official ticket for this issue for further investigation as otherwise I am going to have to leave TalkTalk as something is clearly being blocked on the service which appears to be at odd to the traffic management policy.
Andy.
on 23-11-2023 12:54 PM
Hi Andy,
I don't really know what else to suggest. Do you know if the IT department are aware of other TalkTalk customers with this issue or other TalkTalk customers not experiencing this issue?
on 22-11-2023 02:28 PM
Hi Michelle,
I have just checked and non of the security setting are activated.
Andy.
on 22-11-2023 01:05 PM
Sorry about that Keith, I must have missed that. No worries 🙂
on 22-11-2023 01:03 PM
Hi @Anonymous
This one has been going on for a while now, every time I asked a question, the customer would not often reply, probably due to confidentiality concerns. Therefore I have no idea if it is related to the VPN in question, as I have no idea what one it is.
on 22-11-2023 12:21 PM
@KeithFrench - Have you ever come across this before in relation to the VPN issue?
on 22-11-2023 12:00 PM
Thanks for the PM. Are the Homesafe/kidsafe settings still show as not active in your My Account?
on 22-11-2023 11:55 AM
Hi Michelle,
I sent you a DM with further testing I have done. Hopefully you can come back with further suggestions. Thanks.
Andy.
on 10-11-2023 06:21 AM
Thanks for testing and I'm sorry to hear this. I'm not sure what else we can advise as the VPN connection should work fine.
on 09-11-2023 03:23 PM
I received the router and have now tested with no change, the same issue persists.
Andy.
on 01-11-2023 07:50 AM
Hi Andy
I've requested that a replacement router is sent, please allow 48hrs for this to arrive.
on 01-11-2023 07:35 AM
Yes please as this is causing my wife severe issues for work.
regards,
Andy.
on 01-11-2023 06:16 AM
Hi Andy,
The VPN connection should work fine as we don't block VPN. Would you like us to send a replacement router for testing purposes?
on 31-10-2023 10:50 PM
I have checked on none of the security features are active.
Andy.
on 27-10-2023 12:09 PM
Hi Andy,
Ok thanks for confirming. Could you try logging into your My Account please to check if any of the HomeSafe categories are ticked.
on 27-10-2023 11:58 AM
I've never heard of HomeSafe/Kidsafe so can't say. It's certainly nothing I would have configured on any router.
Andy.
on 24-10-2023 06:41 AM
Can I just confirm, are you using HomeSafe/Kidsafe?
on 23-10-2023 03:53 PM
Hi Chris,
My wife transferred to a new department and so this activity was never performed before by her. It's never worked. At first if was thought it was the laptop or something on it, so that has been replaced but with no change in behaviour, IT have looked at the config and it is identical to colleagues which is why we did the mobile hotspot test and found it worked on a hotspot and not on the home internet.
Andy.
on 23-10-2023 03:51 PM
Hi Chris,
My wife transferred to a new department so this activity was never performed before by her. It's never worked since she started the new role. At first if was thought it was the laptop or something on it, so that has been replaced but with no change in behaviour, IT have looked at the config and it is identical to colleagues which is why we did the mobile hotspot test and found it worked on a hotspot and not on the home internet.
Andy.
