Web site error
Pash02
Enlightened One
Message 13 of 13
Hi ya I keep getting a website error message when trying to log in or create an account.
I was sent an email to confirm my work email but when I click on it i get the website error.
I had an account over a year ago using my personal email and even when I tried to log in using this email i still get the error message.
I have tried on 2 phones and my PC using chrome and edge but nothing works.
All history is deleted and I have run ccleaner, my antivirus is Norton but unsure how to turn it off temporary to see if its that.
The log in website I'm trying to access is https://academy.aneemo.com/p/rough-sleeper-mental-health-awareness-free
update i can access the site and login when using my mobile data and also a different WiFi network but not at home on my TT WiFi.
12 REPLIES 12
Message 1 of 13
I've sent the link, please click below. Thanks
Raising a complaint
Message 2 of 13
Good to hear that you got this resolved.
There's a Complaints procedure linked at the foot of every Talktalk page.
Message 3 of 13
How do i log a complaint against Sumit?
I have just done an online chat with Keneth and he fixed my issue in ten minutes by turning off scam protection and virus alerts.
No messing with router settings or DNS and command prompt stuff
Keneth is a mega huge credit to TT and that Sumit needs re training or sacking.
Message 4 of 13
I'm really sorry about this, I'm unable to assist with full fibre hence I've directed you to a department that can help. Please hang in there and have them complete diagnostics on this.
Message 5 of 13
Ugg and double Ugg all they hung on me and told me to do an online check now talking to on line chat ekkkkkkk.
So much easier and no stress using this forum in the old days to get things sorted.
All they have done is given me tons of things to check in a list and then told me to take my time and now they have ended the chat all in the space of 3 minutes!!! seriously
Doing the jobs ain't the issues but when they say they will be here to help and then just end the chat!"  not happy
The agent is called Sumit
  1. Check Router DNS Settings
Sometimes TalkTalk routers use custom DNS that may block certain sites.
Log in to your router admin page (192.168.1.1)
Go to Advanced Settings > Internet > DNS
Change DNS to:
Primary: 8.8.8.8
Secondary: 8.8.4.4 (Google DNS)
Save and reboot the router.
  1. Disable WebSafe / HomeSafe Filters
TalkTalk has built-in filters that may block educational or login pages.
Go to TalkTalk My Account
Navigate to My Services > WebSafe
Turn off KidsSafe and VirusSafe
Wait 10–15 minutes and try accessing the site again.
  1. Temporarily Disable Norton Antivirus
To test if Norton is interfering:
Open Norton
Go to Settings > Real-Time Protection
Temporarily disable Smart Firewall and Web Protection
Try accessing the site again
⚠️ Don’t forget to turn Norton back on after testing.
  1. Flush DNS Cache on Your PC
Sometimes your computer stores outdated DNS info.
Open Command Prompt as Administrator
Type: ipconfig /flushdns
Press Enter
Here’s how you can find and open Command Prompt on your Windows PC:
🖥️ Method 1: Using the Start Menu
Click the Start button (Windows icon) in the bottom-left corner.
Type cmd or Command Prompt in the search bar.
Right-click on Command Prompt in the results.
Select “Run as administrator” (important for DNS flush).
🖱️ Method 2: Using Keyboard Shortcut
Press Windows Key + R to open the Run dialog.
Type cmd and press Enter.
To run as administrator, instead type cmd, then press Ctrl + Shift + Enter.
Just to help you better, If you run into any problems, you can always head over to My Connection support.talktalk.co.uk/. It's a handy place for self-help and talking to our team.
Message 6 of 13
Great, I'll need you to contact our full fibre team so they can run checks on this for you.
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
You can use the number or chat link provided above. Thanks
Message 7 of 13
Now home  🙂
Message 8 of 13
No problem, let me know as soon as you get home. Thanks
Message 9 of 13
Hi ya
I will be home in about an hour.
Message 10 of 13
Ok so I'm guessing this might also be an internet problem, kindly confirm if you are currently at home? Thanks
Pash02
Enlightened One
Message 11 of 13
Hi ya
No to Everymail, bever heard of it.
I also used my work email account and my TT email account to access the training.
Just at home using the TT WiFi nothing works.
siphosethu-TT
Message 12 of 13
Hi there @Pash02, please confirm if you've received any notification asking you to sign up to Everymail. Thanks
