Which is latest Sagemcom?
on 08-04-2024 11:45 AM
Message 3 of 3
Hi, I have just gone over to FF150 but the new Eero 6 is no good As I have to run a mesh to get WiFi anywhere but the lounge. I was sent a Fast 5364 last year but never set it up as the 1 already in use is the 5464. It makes sense the higher the number the newer the unit but thought I'd check as currently still only getting low speeds. Version is SG4K100174
Labels:
- Labels:
Router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 08-04-2024 03:07 PM
Message 1 of 3
If you have WiFi issues I can help, the Eero 6 will run as a mesh with one or more extra Eeros. The 5364 or 5464 can also run as a mesh with the Sagemcom FAST266 WiFi booster, which is very good. I would recommend checking for WiFi interference before considering getting extra products.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-04-2024 11:53 AM
Message 2 of 3
Hi Jackie,
The only difference between the 5364 and 5464 is the 5464 has a telephone port to connect a telephone if you have digital voice service (VoIP)
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Email no longer works with iOS Mail. Only webmail. in Email
- Amounts of bills may be incorrect in Billing
- My 5+ year old faulty router needs replacing...Suggested by online & phone TT tech support. in Fibre
- PC Running Slow - Wi-Fi Issue - Will Full Fibre Solve It? in Broadband
- AVOID TALKTALK: TalkTalk cancelling my transfer to a different broadband provider in Billing
