WiFi disconnecting just 2 devices several times a day
Katehughes
Message 3 of 3
We recently moved over to talk talk from Now Tv. Since the move 2 weeks ago our 2 LG tvs constantly drop off the WIfI several times a day. All other devices stay connected but the two tvs say not connected and we have to reconnect constantly, this never happened pre change over of supplier, Eero app shows no problems and wifi is obviously on as other devices not affected. Any ideas please
Message 1 of 3
Hi @Katehughes
I'm sorry to hear this. I can see that @KeithFrench has offered to help.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 2 of 3
Hi @Katehughes
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
