on 25-11-2024 08:57 PM
Anybody have this problem if so how can I put it wright
on 03-12-2024 07:29 AM
on 27-11-2024 01:30 PM
Thanks for the Private Message.
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
on 27-11-2024 01:22 PM
I have replied to your Private Message.
on 27-11-2024 07:09 AM
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send a new router for testing.
on 26-11-2024 10:11 PM
Hi @Anonymous
The customer has the Huawei DG8041W, please can this be replaced before I start any diagnostics?
on 26-11-2024 10:54 AM
on 26-11-2024 08:56 AM
Thanks Keith 🙂
on 26-11-2024 08:40 AM
Hi @Anonymous yes of course I will try to help @Westhighland10 when iI know about the router model
on 26-11-2024 07:19 AM
I'm sorry to hear this. Are you using a Wifi Hub router or an eero please?
@KeithFrench - would you be able to offer advice please?
