Internet Drops Intermittently
on 08-01-2025 10:31 AM
Message 14 of 14
Hello
For about a month now we have been having problems with our usually very stable Fibre 35 service. The problems started at the beginning of December. I have spoken to support on numerous occasions which in itself is very frustrating. So far we have
1. Replaced the router
2. Reset the router, left if off for 20 mins
3. Updated the firmware on the router
4. Changed wifi channel
5. Had a visit from a talk talk engineer
6. Had a visit from BT openreach engineer, who replaced an internal cable and re terminated at the box for us just to be safe as he could not locate a problem but can see that we are dropping.
Im at my wits end with it, my daughters and my wife rely on it for school/work etc . When it goes it just drops for all of us and we have to restart the router. So far talk talk have not been able to resolve the issue.
Can anyone help ?
thanks
Paul Hutchinson
Labels:
- Labels:
Connection
Engineers
Router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
13 REPLIES 13
on 10-01-2025 06:38 AM
Message 1 of 14
Hi Paul,
How are you getting on?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 02:20 PM
Message 2 of 14
Hi @KeithFrench
Ok thanks for the information i will not do that
I will have a look at your guide when i can and get you the information
I do not know how many devices use 2.4 but most of our devices are fairly modern so i would think no many, they may resort to 2.4 if they go upstairs as the router is downstairs.
thanks
Paul
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 12:57 PM
Message 3 of 14
Hi @phutch995
Do not turn either WiFi band off, one will not interfere with the other, as they are in different parts of the frequency spectrum. Plus, if you do and you have the Sagemcom FAST5364 or 5464 routers, then there is a bug in the firmware that will prevent them from coming back properly if re-enabled, even though the router UI will say that they are up. Whilst it is possible to have separate network names (SSIDs) per WiFi band, it is no longer recommended. Do you have many smart home devices that only work in the 2.4GHz band?
What needs to be done is to remove guesswork from the equation & start working your way through my guide to get me the diagnostic information I need to check out your WiFi.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 12:08 PM
Message 4 of 14
Hi @KeithFrench
Im starting to think its not a line issue, i was with the BT engineer last Thursday he was very thorough and went above and beyond even though he could not find an issue with the line at the time he was here. He even replaced the internal part of the cable just in case. He was in the road outside the house for 30 minutes and then left to go and change our connection at the exchange. He was not able to locate a fault.
I work in IT support and know a small amount about wifi - im no expert
I was thinking about changing the configuration so 2.4 and 5 Ghz had their own ssid and password - would you recommend that ?
I was also considering turning off 2.4Ghz and seeing if that made a difference, we should all be able to use 5 Ghz ?
My eldest daughter also has a powerline adapter to her room, its worked fine for 10 years, i was considering unplugging this and seeing if that made any difference
thank you for your help
Paul
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 11:49 AM
Message 5 of 14
Hi @phutch995
It still sounds like a router/line issue to me from @Anonymous diagnosis.
My recommendation is to get that fixed first & then we can identify any wireless issues or configure it to be at its best.
That said, you asked, so I will deliver!
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 11:42 AM
Message 6 of 14
Hi Michelle
On Monday night it did not go red / orange it stayed white, but we had no service at all me my wife my eldest daughter all confirmed this we were sat together. I would say this is how we normally have the problem
On a previous occasions before the bt engineer visit it had gone red and we were unable to get it to connect but after leaving it for the day it did reconnect eventually in the evening.
@KeithFrench I would very much request your guide and help, many thanks
thanks
Paul
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 11:35 AM
Message 7 of 14
Hi Paul,
Ok thanks for confirming. Does the light go red on the router when the connection is dropping? As the line test is clear the only option we have is to arrange an engineer visit to the property to investigate further (they would also investigate externally too) if all testing has been completed with alternative equipment at the test socket.
If you'd like to go ahead with this then please let us know and we can confirm some information with you to arrange this engineer visit.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 11:33 AM
Message 8 of 14
Hi @phutch995
Sorry, I thought that @Anonymous had identified reconnections on the line, but maybe that was you rebooting the router.
Which make/model of router do you have - the Sagemcom FAST5364?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 11:26 AM
Message 9 of 14
Hi Michelle
Yes its tests fine this has been done on multiple occasions. It can then be stable for 1 -5 days and then will go again. When it goes it will then happen multiple times in one evening. On Monday evening it went 4 times between 5pm and 10pm.
I dont believe its weather related i was off work yesterday and we have snow and freezing conditions and it was fine
@KeithFrench unfortunately Michelle has not yet identified the problem if you are able to help it would be much appreciated
thanks
Paul
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 11:15 AM
Message 10 of 14
Hi @phutch995
I can see that @Anonymous has identified the problem. However, after it is fixed if you have any wireless or other issues, I will be very happy to help.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 10:56 AM
Message 11 of 14
Hi Paul,
Of course 🙂 I work for TalkTalk dealing specifically with Broadband and Home Phone Faults.
I've run a test on your line now which is clear, however I can see re-connections on the line. The connection looks stable for the last 24hrs, does your connection go through a period of stability before it starts dropping again? Have you noticed if it appears to be weather related at all?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 10:40 AM
Message 12 of 14
Hi Michelle
Thanks for your reply i have done this
Can i ask what is your role ? will you be able to help ?
Paul
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-01-2025 10:34 AM
Message 13 of 14
Morning Paul,
- Name
- TalkTalk Telephone number or Account number
- Alternative contact number
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
