Landline Phone not completing outgoing/incoming calls
mrf3049
Message 4 of 4
My landline - internet connected - if I make an outgoing call it dials but doesn't connect but just gives a continuous tone.   Incoming calls ring but on picking up  no connection.
Support chat line very very slow and cut me off !! after 25 minutes  then didn't respond when I tried again  - so no help there.
Incoming calls now seem to be working  - this is 1 hour after finding the problem and starting to try to sort it -  but outgoing still not working.
I think it needs a line check but the facility in support section has this is not possible as I have both full fibre and copper wire connections  . I have only full fibre but the copper wire was not removed when fibre was installed  as it was BT
What a palaver
Where do I go from here please ?
3 REPLIES 3
Message 1 of 4
Good morning,
No problem at all. I'm glad to hear that this is now working ok for you. Please let us know if you do need any further assistance 🙂
Message 2 of 4
Sorry not to respond sooner as I've been away
I have full fibre with my copper wire landline replaced by this - I'm guessing that is VoIP
Fortunately the fault seems to have corrected itself - or someone somewhere did something -  as the phone has been working for both in/outgoing calls since yesterday morning.
Sorry to have taken up your time but having been used to the 50+ year reliability of a copper landline, a service which fails for the second time in twelve months is disturbing  compounded by a support 'chat' service that is inadequate.
Anyway, thank again for getting back to me
Chris-TalkTalk
Message 3 of 4
Hi mrf3049,
Do you have Full Fibre with VoIP?
