WiFi dropping out intermittently causing my to to freeze
Westhighland10
Message 10 of 10
Anybody have this problem if so how can I put it wright
9 REPLIES 9
Message 1 of 10
Message 2 of 10
Hi @Westhighland10
Thanks for the Private Message.
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
Message 3 of 10
Hi @Westhighland10
I have replied to your Private Message.
Message 4 of 10
Hi @Westhighland10
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send a new router for testing.
Message 5 of 10
Hi @Anonymous
The customer has the Huawei DG8041W, please can this be replaced before I start any diagnostics?
Message 6 of 10
Hi @Westhighland10
Message 7 of 10
Thanks Keith 🙂
Message 8 of 10
Hi @Anonymous yes of course I will try to help @Westhighland10 when iI know about the router model
Message 9 of 10
I'm sorry to hear this. Are you using a Wifi Hub router or an eero please?
@KeithFrench - would you be able to offer advice please?
