Wifi
RobDG
Message 5 of 5
My wifi defaults to channel 36 on which my devices struggle to connect. I have changed the channel to 42 & more recently 48 when I find the signal satisfactory but after a day or two the router changes back to channel 36.  I have tried auto some time ago but most of the time channel 36 is chosen.
Is the router defective?
RobDG
4 REPLIES 4
Message 1 of 5
Hi RobDG
How's the connection been since we switched the WIFI optimisation off yesterday morning?
Message 2 of 5
Hi RobDG
I've switched the WIFI optimisation off, please let us know how the connection compares.
Message 3 of 5
Hi Rob,
Can I just confirm, are you using the wifi hub or the eero?
  • Name
  • Telephone number
  • Alternative contact number
Message 4 of 5
If you have a Hub 2 then WiFi optimisation (sic) is enabled as standard. This overrides any changes that you make, because it thinks it knows best. This is set at network level and cannot be changed by the user.
If you can tell us your router model and that you would prefer optimisation turned of then please confirm by reply and the support team here can disable this for you. Make sure your community profile contains your account number so that they can identify your account.
