Yale smart alarm offline
amos19
Message 50 of 50
Hi just gone on to fiber had new eero modem my yale smart alarm worked for couple of hours, then the modem done a update now the alarm is offline and i cant reconnect i tried rebooting the alarm and modem but us still off line, any advice or suggestion's would be great, Thanks
49 REPLIES 49
Message 1 of 50
Okay no worries. Please don't hesitate to chat back should you require any other assistance. Thank you for contacting TalkTalk. Goodbye 🙂
Message 2 of 50
Yes still working, so i think the problem all long was the eero Security  on the modem turned off and working so i dont know if i needed to change dns but im going to leave as it is working
angelique-TT
Message 3 of 50
Hi there @amos19. Is everything still working okay?
Message 4 of 50
Just update the alarm went off line so i turned off Advanced Network Security still ok after 14hr first time failed after 6hr so fingers crossed
Message 5 of 50
Just changed the dns, left eero secureon works good at moment wait to see thank you every one who give advice Thanks Amos
Message 6 of 50
No, it will not fail whatever you do. I am suggesting that you don't enable advanced security or block any websites from the Eero.  No content filters, do not block websites or apps.
Also, my advice from Yale was to ensure port forwarding was enabled for the alarm hub and change the DNS.
Message 7 of 50
Hi @amos19
I am not sure about port forwarding being required, unless Yale is connecting over the internet to the alarm. However, if you want, I can tell you how to do this.
To change the network DNS servers from the standard TalkTalk DNS servers to something like Google DNS (8.8.8.8 and 8.8.4.4) as an example, do this:-
  1. Open the eero app.
  2. Tap on Settings, then select Network Settings.
  3. Tap on DNS.
  4. In the DNS screen, change ISP DNS (Default) to Custom DNS.
  5. Input your desired IPv4 and/or IPv6 DNS Server addresses.
  6. Tap Save in the top right corner of the screen.
This will reboot your network in order to propagate the settings across your devices.
This may require eero Secure to be disabled.
Enable or disable eero Secure
eero Secure allows:-
  • Advanced Network Security protects your devices from viruses, malware, and phishing.
  • Block Ads removes ads and pop-ups from websites and apps. This can be activated for individual user profiles or for your entire network.
  • SafeSearch prevents inappropriate websites, images, or videos from appearing in search results. This can be activated for individual user profiles.
Content Filters block explicit, illegal, or violent content per each user profile.
However, some customers have noticed that it can also block all websites when searching via Google. These sites are fully accessible directly from the device, just not via a Google search.
To enable or disable eero Secure, from the eero app go to:-
  1. Tap Discover
  2. Tap eero Secure
  3. Tap Advanced Security to toggle the feature on or off.
Message 8 of 50
Hi thanks for your advice so what ever i do will the yale fail at some point, I have been advised to change DNS to 8.8.8.8 i personally dont want to change settings that i dont understand
CharlieMuggins
Message 9 of 50
It's an issue when advanced security is activated on the Eero. If you want to block certain websites on the Eero, the Yale alarm will eventually fail after a period of time. The beeping on the alarm occurs when the hub loses connection.
Yale also suggest you enable port forwarding on 80 and 81 for the hub. You could also enable port forwarding on 8765 and 5222. Also set up a custom DNS to 1.1.1.1 and secondary DNS to 1.0.0.1
The DNS could be 8.8.8.8, or BT or Vodafone, just about anyone except for talk talk.
Message 10 of 50
Yes thats all good, I added 2 pro as thats what tt sent me i have only got the 2 pro on, im waiting for technical to get back to me as why the latest update knock the yale off
Message 11 of 50
Hi @amos19
First off, adding an eero 6 to a network of two eero Pro 6s is counterproductive, as the two Pro 6s will only have the speed of the eero 6. Mixing them in the same network always means they all assume the same specification of the lower specification node. Until your Yale alarm connection is stable, just go with the two Pro 6 units.
You have not confirmed if you have carried out all of my recommendations in my last post (#37):-
Under the circumstances, I would suggest that you delete the complete network and start again. In the app go to:-
Settings> Network Settings
Tap the blue 3 dot icon top right and select Delete Network.
I would probably go further on each Eero, hold the reset button in until the light goes red (about 15 seconds) to do a hard reset.
Then, use the app to gradually add them one by one.
Message 12 of 50
Hi Kanya, no not yet the thought of having hours on chat not looking forward to i i will have to do you have direct link not for me to get past around, but it is 100% the update that done it. Amos
Message 13 of 50
Hi yes manged that was all working till the update in middle night know the alarm gone again
Message 14 of 50
Hi @amos19
You must remove or replace eeros via the app. You can't just go connecting and disconnecting them without it.
Under the circumstances I would suggest that you delete the complete network and start again. In the app go to:-
Then use the app to gradually add them one by one.
kanya-TT
Message 15 of 50
Yes, Amos. Have you contacted the fullfibre tech Support team.
Message 16 of 50
Done update last night back to alarm offline
Message 17 of 50
Hi Keith,
Hope you can help eero pro working as should added another eero6 pro as extender still all working, me being greedy added the old eero6 as extender in another part house, then it started the yale alarm went down and both extender are on wifi so i uninstalled the main one as in remove device but i didnt remove the other eero pro reinstalled main device but cant pair the other pro6, is there a way of unpairing
Amos
Message 18 of 50
You are very welcome.
Message 19 of 50
the alarm and cctv are connected with Ethernet splitter the extender will be used upstairs for wifi and tv so the alarm is staying in the port it is know so there's no change to the settings hopefully, i will give you update tomorow after the eero done its up date
Thanks for your help
Message 20 of 50
All the tests I did yesterday were on V7.8.
If the gateway is the eero 6 Pro, what happens if you add the eero 6 back in as an extender? The crucial thing to check now is do the Ethernet ports of the eero 6 work with the alarm or not. Was it the relatively simple case all along that the ports were faulty?
