ebay being blocked
loxocemus
Message 65 of 65
Hi, I have an issue with Ebay being blocked for me most of the time, occasionally it works for a few days and then its blocked again, I can only access it via a vpn, this is the error
"Access Denied
You don't have permission to access "http://www.ebay.co.uk/myb/WatchList?" on this server.
Reference #18.1e3f655f.1774491197.fd2b810
https://errors.edgesuite.net/18.1e3f655f.1774491197.fd2b810"
its the same regardless of browser or deletion of cookies etc. Does anyone have a solution?
P.S in HomeSafe settings i have scam and virus enabled but no other protection (other than win11 firewall/antiV)
Thank you and Rgds
Edward
64 REPLIES 64
Message 1 of 65
Hi @loxocemus
Thanks for the screenshot of the error.
That says it all, really. It is eBay that is blocking you for some reason. Do they have a support team that you could contact & quote that reference number to? Then come back to me & I'll see what can be done.
Message 2 of 65
sent keith
rgds
edward
Message 3 of 65
Hi @loxocemus
Can you also PM me a screenshot of the error, in case it gives me anything to go on?
Message 4 of 65
hi keith, attached is the trace without malwarebytes running in the background.
rgds
edward
Message 5 of 65
here is the trace keith, i just noticed malwarebytes was running during this, shall i redo?
rgds
edward
Message 6 of 65
This is going to be a bit of a nightmare as the vast majority of the trace is totally encrypted, making legitimate diagnostics very difficult.
Message 7 of 65
Thankyou Keith
rgds
edward
Message 8 of 65
Hi @loxocemus
Thanks for the trace, which I have now deleted from your thread. I will try and have a look at this later today for you.
Message 9 of 65
Hi Keith i have attached the wireshark trace zip and il pm the passw to it. while wireshark was running i tried to access ebays webpage by refreshing it to the access denied error 2 or 3 times. i hope this was correct, via chrome browser.
rgds
edward
Message 10 of 65
I will send a PM to you that contains a link to a guide of mine.
Message 11 of 65
of course keith let me know how to proceed and il send you the results, thanks for your help
rgds
edward
Message 12 of 65
Hi @loxocemus
Thanks for the results that you PM'd me with. As I suspected, they show that you reached the destination. However, something, possibly their web server, is blocking your access. To determine what this is, I will need you to get me a Wireshark trace. I can provide a guide giving full details about getting me the Wireshark trace, which I will analyse for you. Please let me know if you are happy to do this.
Message 13 of 65
Hi keith, As i suspected my access to ebay was just temporary, i am again blocked by the same access denied error, i shall pm you the ping results. this time it occurred while i was browsing ebay, the basket/cart link became access denied followed a few seconds later by the entire site.
Rgds
Edward
Message 14 of 65
thank you for your help ferguson its most appreciated.
rgds
edward
Message 15 of 65
OK, that's fine, both Google, I just use different settings from preference. But if that's what you have in your eero settings then it is not the issue. Thank you for checking and confirming. I think I will leave you in the capable hands of @KeithFrench going forwards!  🙂
Message 16 of 65
hey ferguson, mines is similar to that
IPv4 primary is 8.8.8.8
but
IPv4 secondary  is 8.8.4.4 not the 208.67.222.222 shown above?
rgds
edward
Message 17 of 65
OK, just to satisfy my urge for changing the DNS settings "properly" in the eero here's how to do it.
First, from the home page of the eero app make sure that the security settings are turned off:
Then tap on Settings:
Then tap on Advanced networking:
 And that then on DNS, where you can change the setting from ISP DNS to Customise.
Message 18 of 65
 hi ferguson, windows control panel - network and internet - network and sharing centre, i suppose its considered legacy these days.
rgds
edward
Message 19 of 65
Sorry, I don't know what you mean by "control panel?"
Message 20 of 65
Thankyou for your help Keith, when ebay is blocked again i shall send you the results from a tracert ping
rgds
edward
