on 26-03-2026 02:21 AM
Hi, I have an issue with Ebay being blocked for me most of the time, occasionally it works for a few days and then its blocked again, I can only access it via a vpn, this is the error
"Access Denied
You don't have permission to access "http://www.ebay.co.uk/myb/WatchList?" on this server.
Reference #18.1e3f655f.1774491197.fd2b810
https://errors.edgesuite.net/18.1e3f655f.1774491197.fd2b810"
its the same regardless of browser or deletion of cookies etc. Does anyone have a solution?
P.S in HomeSafe settings i have scam and virus enabled but no other protection (other than win11 firewall/antiV)
Thank you and Rgds
Edward
Wednesday
HI, just an update re my ebay access denied error, it seems i now have unfettered access to ebay for a while now (knock on virtual wood) i contacted ebay tech support and they said they'd look into it. at the same i was trying to fix a windows nightmare issue of firmware protection in core isolation being disabled and one of the things i tried (unsuccessfully for the error) was to clear the TPM, and i noticed ebay worked thereafter, so i dunno if it was me or ebay tech support, but here's hoping i can continue to buy junk off ebay i don't need without resorting to a vpn.
id like to give a special thanks to Keith French, he spent a lot of time talking me thru what to do, which wasn't easy for him as i am a bit of tech idiot. So thanks Keith 🤘
thankyou everyone.
rgds
Edward
on 30-03-2026 03:00 PM
Hi @loxocemus
Thanks for the screenshot of the error.
That says it all, really. It is eBay that is blocking you for some reason. Do they have a support team that you could contact & quote that reference number to? Then come back to me & I'll see what can be done.
on 30-03-2026 02:56 PM
sent keith
rgds
edward
on 30-03-2026 02:50 PM
Hi @loxocemus
Can you also PM me a screenshot of the error, in case it gives me anything to go on?
on 30-03-2026 02:43 PM - last edited on 30-03-2026 02:49 PM by KeithFrench
hi keith, attached is the trace without malwarebytes running in the background.
rgds
edward
30-03-2026 01:43 PM - edited 30-03-2026 01:45 PM
here is the trace keith, i just noticed malwarebytes was running during this, shall i redo?
rgds
edward
on 30-03-2026 01:08 PM
This is going to be a bit of a nightmare as the vast majority of the trace is totally encrypted, making legitimate diagnostics very difficult.
on 30-03-2026 10:01 AM
Thankyou Keith
rgds
edward
on 30-03-2026 09:51 AM
Hi @loxocemus
Thanks for the trace, which I have now deleted from your thread. I will try and have a look at this later today for you.
on 29-03-2026 10:44 PM - last edited on 30-03-2026 09:50 AM by KeithFrench
Hi Keith i have attached the wireshark trace zip and il pm the passw to it. while wireshark was running i tried to access ebays webpage by refreshing it to the access denied error 2 or 3 times. i hope this was correct, via chrome browser.
rgds
edward
on 29-03-2026 10:24 PM
I will send a PM to you that contains a link to a guide of mine.
on 29-03-2026 10:07 PM
of course keith let me know how to proceed and il send you the results, thanks for your help
rgds
edward
on 29-03-2026 10:04 PM
Hi @loxocemus
Thanks for the results that you PM'd me with. As I suspected, they show that you reached the destination. However, something, possibly their web server, is blocking your access. To determine what this is, I will need you to get me a Wireshark trace. I can provide a guide giving full details about getting me the Wireshark trace, which I will analyse for you. Please let me know if you are happy to do this.
29-03-2026 04:44 PM - edited 29-03-2026 04:48 PM
Hi keith, As i suspected my access to ebay was just temporary, i am again blocked by the same access denied error, i shall pm you the ping results. this time it occurred while i was browsing ebay, the basket/cart link became access denied followed a few seconds later by the entire site.
Rgds
Edward
on 28-03-2026 04:47 PM
thank you for your help ferguson its most appreciated.
rgds
edward
on 28-03-2026 04:43 PM
OK, that's fine, both Google, I just use different settings from preference. But if that's what you have in your eero settings then it is not the issue. Thank you for checking and confirming. I think I will leave you in the capable hands of @KeithFrench going forwards! 🙂
on 28-03-2026 04:34 PM
hey ferguson, mines is similar to that
IPv4 primary is 8.8.8.8
but
IPv4 secondary is 8.8.4.4 not the 208.67.222.222 shown above?
rgds
edward
on 28-03-2026 04:28 PM
OK, just to satisfy my urge for changing the DNS settings "properly" in the eero here's how to do it.
First, from the home page of the eero app make sure that the security settings are turned off:
Then tap on Settings:
Then tap on Advanced networking:
And that then on DNS, where you can change the setting from ISP DNS to Customise.
on 28-03-2026 04:07 PM
hi ferguson, windows control panel - network and internet - network and sharing centre, i suppose its considered legacy these days.
rgds
edward
on 28-03-2026 04:04 PM
Sorry, I don't know what you mean by "control panel?"
