eero 6 using wrong channel
silvergirl
Super Duper Contributor
Message 7 of 7
The 5GHz band of my eero 6s have suddenly started using channel 122. This is above the channel range supported by the Wi-Fi adapter in my PC (RTL8821CE) and now I can only use the 2.4GHz band, which is very slow. I understand that there is a patch for this, please can it be applied ASAP?
Silvergirl
Silvergirl
6 REPLIES 6
Message 1 of 7
silvergirl
Message 2 of 7
Hi Michelle,
Thank you. At the moment I am on channel 116 - technically still too high but showing 5GHz. I am hoping this is steady and I will let you know if anything changes.
Silvergirl
Message 3 of 7
Hi @silvergirl
The fix has now been applied. Please can you retest and let us know how you get on.
Message 4 of 7
Hi Keith,
Ah right sorry for the confusion. I'll pass it over now.
Message 5 of 7
Hi @Anonymous
This just needs the standard patch applied by eero support via Devices to restrict the eeros to channels 36 - 48, This is the same patch that you got applied to my errors some time ago.
Message 6 of 7
@KeithFrench - would you be able to offer advice please?
