eero to ethernet via powerline
on 28-06-2024 07:58 AM
Message 2 of 2
We've just had full fibre installed with an eero. It works OK with our phones and laptops but we have a couple of devices around the house which only have ethernet. The old router had four ports and we used one to connect to a powerline apapter which then gave access to these devices. Since the eero only has two ports and one is used by the telephone we can't do this now. My powerline adapter has two ports, can I use one port on the eero to the powerline and then the second port on the powerline for the phone apapter? I don't want to use a five port switch since my wife is already unhappy with the amount of kit and wires in the corner of the living room.
Labels:
- Labels:
Powerline adapters
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
1 REPLY 1
on 28-06-2024 08:04 AM
Message 1 of 2
Hi Mick74,
Yes, I think this should work, certainly worth a try if you really don't want to use a switch
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
