eero
Peanic
Message 16 of 16
I want to be able to choose which frequency and channel various devices use.
15 REPLIES 15
Message 1 of 16
Good morning,
Just checking back in to see how you're getting on?
Message 2 of 16
Good morning,
I'm sorry for the delay. I've been advised that the fix has now been applied. Please let us know how your connection compares.
Message 3 of 16
Hi Peanic,
I've chased this for an update now.
Peanic
Message 4 of 16
Thank you Michelle
Message 5 of 16
Hi Peanic,
I'm sorry to hear this. I've passed this over to our Devices Team now and will post back here as soon as I receive an update from the team.
Message 6 of 16
Hi Chris. Thanks for getting back to me.
yes, alas,.
paul
Message 7 of 16
OK thanks. Are you still experiencing the slow speeds on the iMac?
Peanic
Message 8 of 16
Thanks Chris - just updated info.
Message 9 of 16
Hi Peanic,
  • Name
  • Telephone number
  • Alternative contact number
We'll then pass this over to our Product team. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Message 10 of 16
First off, I have asked one of TalkTalk's support to pick your thread up and iapply the channel 155 patch for you. Would you like my help to investigate the 2.4GHz problem.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
Peanic
Message 11 of 16
Thanks Keith.
The problem is eero is allocating 2.4, channel 6 to the iMac - its slow!
I'm amazed that for a wifi6 device that the eero doesn't have the functionality that most other router have - the ability to choose frequencies and channels. Really disappointing actually.
Looking at Radio Analytics it does show channel 155 as you say. i've got 4 devices using 5 and 4 using 2.4.
Frustrated, I connected the iMac to an ethernet port.
Message 12 of 16
Which channel in the 5GHz band is your Eero using? If you look in the Eero app & go to Radio Analytics it should give you the channel information there. The speeds you mention make me think that you might be using the 2.4GHz band. Some customers have recently experienced a problem where the 5GHz channel is locked on 155, which is not supported by a lot of WiFi adapters, hence they are forced to use the slower 2.4GHz band.
Message 13 of 16
Hi Michelle - thanks for responding and apologies for not getting back to you.
Such functionality would be very very welcome.
At the moment the router is automatically allocating a channel and frequency to the iMac and my Tx rate is 130mbps. When with BT it was 247mbps (I used 5ghz band).
I appreciate that there are bottlenecks between what comes into the house and the device (e.g. network card) but one of the reasons I joined Talktalk was because of the wifi6 router - better coverage and potentially better speeds. Unfortunately a drop fro 247 to 130 has been painful!
Thanks again
Paul
Message 14 of 16
At present this is not possible, however I believe that this functionality may be coming. Are you experiencing an issues with your connection?
Gondola
Message 15 of 16
Your expectation is not possible.
The eero app does have Troubleshooting options on the Settings tab. Have you looked there? Is there a particular issue you wish to solve that's not covered in Troubleshooting?
