error code 502
Barrowman
Message 43 of 43
“Hi, my website is showing a 502 Bad Gateway error when I turn on my laptop. Is it  possible to check if the server is down or if there’s a misconfiguration on your end?” I get the same message on my iPhone.
I'm an 81 year old if anyone can help in laymens terms it would be appreciated. Thank you. Oh, and I have full fibre 150.
Barrowman
42 REPLIES 42
Message 1 of 43
Thank you so much, you too @Barrowman 🙂
Message 2 of 43
I would love to do that for you, however you would need to please contact our Better value or customer loyalty team and find Better deals available to you.
03451720088 - Voice - Monday - Friday 9am - 7pm ; Saturday - 9am - 6pm ; Sunday - Closed.
Barrowman
Message 3 of 43
Thank you amahle-TT
You could always get a reduction in my monthly charge reduced as TT seems to be getting expensive!
I bet you wished you never asked now!!
Best wishes....
Barrowman
Message 4 of 43
Thank you so much for your feedback, we are glad that the issue has been resolved.
While I still have you on the platform, would there be anything else you would like for me to further assist you with apart from what have been discussed?
Barrowman
Message 5 of 43
Hi Guys. siphosethu-TT  &  @nameunknown
I tried changing to the Google DNS server earlier this week which made no difference to the error code on boot up.
But!!  The problem has now been resolved, and you may well find you will want to keep the cause in mind for future reference, well what was it I hear you saying - a dead internal battery, new one fitter and it now works perfectly.
Thanks for your help......
Barrowman
Message 6 of 43
Will be here whenever he feels better, wish him a speedy recovery for me. Thanks
Barrowman
Message 7 of 43
Hi Guys.
This is Mrs Barrowman, I'm sorry to say my huband had a fall on Monday and his hands are bandaged up so he wont be able to do the recommeded tasks for a while, he will do them as soon as he can and let you know the outcome. Thank you for your patience
Barrowman
Message 8 of 43
Thank you for this. 🙂 @Barrowman
Barrowman
Message 9 of 43
Hi @sabelo-TT  please see my last post. Will keep you informed. Thanks.
Barrowman
Message 10 of 43
Hello there @Barrowman, have you tried the steps provided by @nameunknown_ ?
Barrowman
Message 11 of 43
Thank you @nameunknown_
 I will try this tomorrow when my house is quieter, grandkids will have gone home!! 😁 and I will let you
know how I've got on with it.
Thank you.
Barrowman
Message 12 of 43
@Barrowman
Okay, let's see if using the Google DNS servers instead of the TalkTalk DNS servers makes any difference.  I am using the Google DNS servers, and I have never had any issues.
Click on Start in the taskbar to open the Windows menu, start typing the word Settings, then click on 'Settings system' at the top of the list.
In the Settings window, click on 'Network & internet' on the left side of the window.
The next step depends on whether you are using ethernet (a cable connection to the router) or wifi.
If you are using ethernet, then click on the arrow to the right of Ethernet.
If you are using wifi, then click on the arrow to the right of wifi, then click on the arrow to the right of 'Hardware properties'.
If you sometimes connect your computer to the router via ethernet, and sometimes via wifi, then you would need to repeat the remaining steps for both ethernet and wifi. In that case, I suggest you make the changes for one of them, and see if it makes any difference, before making the changes to the other.
Next, click on the Edit button to the right of 'DNS server assignment'. In the 'Edit DNS settings' window, click on the down arrow, and select 'Manual', then click the button under IPv4 to change the setting to On.
Enter 8.8.8.8 in the box under 'Preferred DNS', and enter 8.8.4.4 in the box under 'Alternative DNS', then click on the Save button.
Edit DNS settingsEdit DNS settings
If at any time you need to undo the changes, then follow the steps above to open the 'Edit DNS settings' window, click on the button under IPv4 to change the setting to Off, and click on the Save button.
Hopefully, you find that you no longer see 'this site can't be reached'. If you do, then we would need to look at other possible causes, such as the firewall.
Changing the DNS settings in your computer only changes the DNS servers used when accessing the internet via your computer. If changing the DNS settings on your computer allows you to access the sites you were previously unable to access, then it would be best that the DNS settings are changed in your router settings, so that you can also access the sites using your iPhone when connected to the router via wifi.
Let us know how you get on.
TalkTalk is fine, when there are no issues, but getting issues resolved can be a real headache.
Incorrect information on TalkTalk help pages is unhelpful.
Barrowman
Message 13 of 43
Hi @nameunknown_
Are you still getting 'this site cannot be reached'?  Yes I am.
Did you also clear the browser cache, and do the DNS flush? Yes they were both cleared
I have Windows 11 Home edition and if you can make it as easy to follow as your previous instructions
then I'm happy to give it a go.
Oh, I've checked my DNS on my iPhone and it is the 79.79.79.79 and 79.79.79.80 if that
makes any difference at all.........
Barrowman
Message 14 of 43
@Barrowman
As I suspected you are using the TalkTalk DNS servers, which can show as the gateway IP address, i.e. an address like 192.168.4.1 (as in your case), or as 79.79.79.79 and 79.79.79.80, depending on how DNS has been set in the router settings.
Changing the DNS servers to servers other than TalkTalk's can sometimes resolve 'this site cannot be reached'. The DNS servers can be changed in the router settings or by changing the network settings on your computer. Any other devices connected to the router would still use the DNS server settings in the router.
Changing the DNS settings in your router would best be done by someone who is familiar with doing that and has access to your router, rather than by me providing you with instructions remotely. However, if you have Windows 11, then I would be happy to talk you through making the changes to the network settings on your computer, because it is straightforward to do on Windows 11.
If you do not know what version of Windows you have, then you can check by opening the Windows menu, typing the word winver, and clicking on where it shows 'winver Run command'.
Barrowman
Message 15 of 43
Hi again @nameunknown_
I've managed that. The default DNS is shown as: 192.168.4.1
It does however show another DNS: 192.168.4.24 as I.Pv4 Prefered.
Barrowman
Message 16 of 43
@Barrowman
Okay, what else have you already tried?
What about clearing the browser cache?
To clear the browser cache, open the browser window with just a new tab open, i.e. no web pages open, press the Ctrl+Shift+Delete keys together to open the window for clearing data. Select the longest time range, e.g. 'All time' or 'Everything', and tick 'Cached images and files' or 'cached files and pages'. Remove ticks on other options (by clicking on the tick) or leave them, if you are happy to clear those options as well. When you have finished selecting, click on the 'Delete data' button.
Have you tried flushing the DNS cache?
To do this, you need to open an administrator Command Prompt window. Click on Start in the taskbar to open the Windows menu, then start typing the word Command. You should see Command Prompt at the top of the list. Right click on it, and then click on 'Run as administrator'.
In the Command prompt window, type
ipconfig /flushdns
Whilst in the Command Prompt window, you could also type
ipconfig /all
and report back to the Community what the DNS servers setting is. I suspect it is set to the TalkTalk DNS servers
79.79.79.79
79.79.79.80
Barrowman
Message 17 of 43
I've done that in total three times now....
Barrowman
Message 18 of 43
@Barrowman
There are various things you can try.
Starting with one of the simplest, if you have not already restarted your router, then you could do that.
Barrowman
Message 19 of 43
Oh, did'nt realise that, thanks @nameunknown_ .
It's pretty much all sites that have a clickable link or a clickable button on them, below is the one
previously mentioned.
pottersleisure2.acemlnb.com’s DNS address could not be found. Diagnosing the problem.
DNS_PROBE_POSSIBLE
Barrowman
Message 20 of 43
@Barrowman
The Community staff don't generally work at the weekend.
What site are you attempting to access when you see 'This site cannot be reached'?
