on 30-11-2023 02:54 PM
hello all, help/advice please
I am shortly having full fibre 150 installed and understand that a new router, eero, will be installed. All I require from my wifi service is as currently used, that is 2 chromebooks, a very occasional ipad and 3 occasional phones. Majority of the time just one chromebook is in use and I use a chromecast for various streaming to the TV. The current talktalk black router handles all this absolutely ok.
So my question is: Is there any point in installing the new router which seems added complications to me and ok to stick with the old one which I assume would carry on as I am used to?
Any input would be appreciated. Thank you.
on 02-12-2023 03:22 PM
Absolutely, yes, no worries. 🙂
on 02-12-2023 09:49 AM
thanks Ferguson. By 'will do the job' does that mean it is capable of giving me the enhanced speed of fibre 150 and would there be any downsides?
thank you
on 01-12-2023 06:52 AM
Please let us know if there is anything else that we can help you with 🙂
on 30-11-2023 05:38 PM
That should work just fine. It's what I used when I first set up, in preference to the eero. Unlike you, I do have digital voice so I secured a Hub 2 which has a VoIP port built in. But if you are going for data only then it will do the job. All you should have to do is connect the WAN port on the router to the LAN port of the ONT once installed.
on 30-11-2023 04:24 PM
Have done Chris and included a photo of the router. Thanks
on 30-11-2023 04:13 PM
hi Keith - talktalk black router routerand no digital voice is required.
on 30-11-2023 03:37 PM
Hi davealbert,
Could you answer Keith's questions and we'll be happy to help
on 30-11-2023 03:18 PM
What router do you have currently? Will you require Digital Voice?
