on 18-12-2024 09:24 PM
I've just bought a Veho Cave HD outdoor security camera, which can be connected to my Moto 9 phone, via a Veho app.
When trying to connect it to my erro it just fails.
Are the two incompatable?
on 19-12-2024 12:52 PM
Once you have connected the camera you can cancel the 5GHz pause in the eero app.
on 19-12-2024 11:50 AM
Hi John,
Just to confirm, the cameras keep intermittently keep dropping connection, is this right?
on 19-12-2024 11:40 AM
Hi Michelle,
Ferguson helped me a lot.
However although his excellent suggestion works, it's only temporary and I need a permanent solution, as the security cameras and the 5kHz wifi need to work continuously and simultaneously.
I now realize that I bought the wrong type of camera (2.7kHz), so we live and learn, even at 80.
Many thanks,
John
on 19-12-2024 07:12 AM
Hi John,
How are you getting on?
on 18-12-2024 10:29 PM
No worries, did it work for you?
on 18-12-2024 10:10 PM
Many thanks for your help Ferguson.
John
18-12-2024 09:41 PM - edited 18-12-2024 09:44 PM
I will move this to the Full Fibre section where it will get attention from the support team. The eero is just a router and should be able to connect to any wireless device. If your Veho camera is 2.4GHz only try temporarily turning off the 5GHz channel :
Temporarily hide 5 GHz:
