poor upload speed
pintudey
Message 51 of 51
I got my Fibre 500 today, downloading speed seems very good as expected however, the upload speed is between 1.5 - 7 Mbps. which is well under SLA (71Mbps) even though the speed test on eero app shows 35Mbps upload.
Also, no eero advanced security is enabled.
Could you please help
Thank you
Pintu
MrDey
50 REPLIES 50
Message 21 of 51
@pintudey
You shouldn't be charged for a replacement eero if you return the previous one. If there wasn't a returns bag with the new one then the support team can arrange for this this to be sent to you. Bear in mind that they won't be back online until Monday.
Message 22 of 51
No one bothered to look into it, I must say it's very unprofessional. I didn't expect this from you.
I have noticed a charge for an eero replacement, which I believe I should not be responsible for. I kindly request guidance on the process for returning one of the eero devices.
Thank you
Pintu
MrDey
Message 23 of 51
Apologies, I'll chase it up again
Message 24 of 51
Any update? still, I haven't been contacted by anyone.
Thank you
Pintu
MrDey
Message 25 of 51
Apologies for the delay, will do
Message 26 of 51
Good morning Talktalk,
I haven't received any contact from the full fibre team, so I would greatly appreciate it if you could give them a nudge and get someone to address this issue urgently. The poor upload speed is causing substantial difficulties for me while working from home.
Thank you
Pintu
MrDey
Message 27 of 51
OK thanks. I'll pass this to our future fibre team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
Message 28 of 51
Hi Chris,
Yes, I have done the test while all other devices disconnected.
I have now done a speed test at ONT, getting really poor upload speed.
Please check the video here. Speed test at ONT
Thank you
Pintu
MrDey
Message 29 of 51
OK thanks, have you tested with just one device connected by wifi and all other devices disconnected? Just wondering if one of your devices is causing the upstream bandwidth issue
Message 30 of 51
test on Fasttest on Fast
MrDey
Message 31 of 51
Good morning Chris,
Yes, I am getting slow upload speed across all my devices.
Android phones/tablets
iPhones
Windows Laptops
Windows Desktops
I am really struggling Teams calls during a presentation.
Thank you
PIntu
Test on a Dell Windows LaptopTest on a Dell Windows Laptop
MrDey
Message 32 of 51
Hi pintudey,
Do you get the slow wifi upstream speeds on more than one device?
Message 33 of 51
Hi Karl,
Would it be possible to move my connection to a different connectorised block terminal port?
Thank you
Pintu
MrDey
Message 34 of 51
Hi Karl,
I am using the new cable, which came with the new eero.
Thank you
Pintu
MrDey
Message 35 of 51
can you swap out the ethernet cable that goes from the ONT to the eero so we know that it is not faulty.
Message 36 of 51
Morning Michelle,
Here are the speed test results directly at ONT.
Pintu
MrDey
Message 37 of 51
Can I just confirm, what speeds do you see if you run a wired speed test directly at the ONT with the eero removed please?
Message 38 of 51
Morning Karl,
Here is the speed test result with the new Eero.
Device that supports wifi 6
 Device that doesn't support WiFi 6
Does it mean, it could be an issue with the cable or ONT device itself?
Pintu
MrDey
Message 39 of 51
Ok, this is a strange issue.  I've a new EERO on the way as I want to see if this will change the readings.  When this arrives, power off the ONT for 30 minutes, connect the new EERO, then power on and set it up.
Message 40 of 51
Morning Karl,
Here is the speed test result after power down for 30 minutes all equipment.
Thank you
Pintu
MrDey
