Home Phone
1471
annienev123
Message 17 of 17
after upgrade to full fibre no 1471 service
p neville
16 REPLIES 16
Message 1 of 17
Hi annienev123,
So is it now working? (There does appear to have been a cancellation order but our systems are showing that the service is currently active and line tests aren't picking up any issues)
annienev123
Message 2 of 17
had a open reach engineer out today no problem with my equipment  you didn,t say when i asked if you had found out if my line had been cancelled p neville
p neville
Message 3 of 17
The telephone number showing on our systems is the one ending 3975, line test is passing. If you call the landline number ending 3975 from your mobile, what happens?
annienev123
Message 4 of 17
if you say no number change    get in touch with open reach and enquire what call out engineer was asked to do and what he said about my number p neville
p neville
Message 5 of 17
my number changed back after i reported having no 1471
p neville
annienev123
Message 6 of 17
what number would have come up on number 17070  when it was was 746271  i have number on mobile that i rage on the 10th get in touch tex  agents and phone agents they will tell you account cancelled  no callblocker why all gone if nothing has been changed
p neville
Anonymous User
Message 7 of 17
Can I just confirm, you can make and receive calls ok but the 1471 service is not working, is that correct?
Message 8 of 17
Hi annienev123
There has to be a fault,  if 17070 reads back 3975 that means we haven't changed your number.
annienev123
Message 9 of 17
re buffering iam piggy backing off sky this morning no buffering no delay
p neville
annienev123
Message 10 of 17
17070   shows my number 263975   i have on my mobile showing i rang the number 764271  which talktalk changed to  still no 1471
p neville
Message 11 of 17
Posting on behalf of the OP, @Arne-TalkTalk, from a PM:
"rang 17070  came up my number ........3975  last thursday the 12th  talktalk sent an open reach engineer to see what was going on he asked for my number .....3975  he said that is not the number i have been given he said the number is  .......4271  while he was here i rang both numbers on my mobile and none were connected the engineer said wait half an hour while i go to the box at the end of our street before you try to make a phone call  after that wait i rang ......3975 not working  rang  ......4271 that worked  i then contacted talktalk  to be told somebody had cancelled my telephone account on january the 2nd  p neville"
Please note, the customer also writes:
"ps this community system is rubbish every time i try to click in a page comes system unresponsive after  30 seconds to a minute page comes on then every page i try to open comes up the same very annoying and time wasting"
So the customer is not even able to reply on here because of the freezing pages that I have previously reported.
The OP concludes with "sorry while all this was happening i could use my phone to call just receive no incoming calls".
Message 12 of 17
Hi @annienev123
Your number has remained the same (ending 3975) what number is read back when you dial 17070?
Message 13 of 17
Elsewhere you have posted that the phone number was reinstated, @annienev123.
Link to post:
https://community.talktalk.co.uk/t5/Home-Phone/No-incoming-calls-since-new-broadband-upgrade/m-p/301...
Worth mentioning that here, and also staff had asked you whether you are now on Full Fibre with VOIP activated?
Please answer that for them to be able to help you.
annienev123
Message 14 of 17
after four hours on text on moblie yesterday and nearly an hour on the phone to talktalk seems nobody has a clue whats going on but i was informed talktalk cancelled my telephone account  then set up another number unbeknown to me i could call out no incoming calls becuse of new number no one had    is cancelling my telephone account a breach of my contract
p neville
Chris-TalkTalk
Message 15 of 17
Hi annienev123,
Is your Full Fibre service up and running? Do you have the VoIP service?
Chris-TalkTalk
Message 16 of 17
Hi annienev123,
Can you add your TalkTalk home telephone number to your community profile and we'll take a look at this for you
Anonymous User
