Home Phone
Call filtering
MikeM48
Message 3 of 3
Our landline is set to require a caller to first state his/her name, as a security feature. We wish to discontinue this, but can't remember how we set this up! Can you help?
Message 1 of 3
Thanks @fr8ys
Message 2 of 3
You can turn this off in My Account.
Instructions can be found here
https://community.talktalk.co.uk/t5/Articles/How-to-use-CallSafe/ta-p/2204789In
Please note that once turned off all your approved and blocked numbers are wiped from the system. If you turn it back on again you will have to start approving numbers again.
