Home Phone
Caller Display not Working
seajays
Message 38 of 38
I just came over from sky a few weeks ago.  I activated caller display, but it isn't working.
I deactivated it, waited a few hours and reenabled it in my account yesterday.  It is showing as an "active add-on" in my account, however it still isn't working.
Caller display was working fine with sky, so I don't think it's an equipment issue.
Can you help?
Thanks,
Colin.
Aquila non captat muscas
37 REPLIES 37
Message 21 of 38
Thanks for confirming. I've passed this over to our Faults Team for further investigation and we will post back as soon as we receive an update. It's possible that the team may also try and contact you directly.
Message 22 of 38
By me a few weeks ago, and also by your representative in online chat. It didn't make any difference.
Message 23 of 38
OK thanks. When you say it's been switched off serval times already, is that by you?
Message 24 of 38
Yes - it's still not working today, and it has been "switched off and on again" several times already.
Message 25 of 38
Could you just confirm it's still not working today, if not then I'll try removing it at our end and re-adding it
Message 26 of 38
Yes, I've tested with a second telephone and it still doesn't work.
I've also taken my telephone to a neighbour's house and tested it there and the caller display is working perfectly.
It seems that caller display is just not functioning on my line.
Message 27 of 38
Hi seajays,
Just to confirm, you've tested with a second telephone?
Message 28 of 38
Still not working.
Message 29 of 38
Thanks for trying that. Everything looks OK from our side so do you have another telephone that you can test with?
Message 30 of 38
No, still same.
Message 31 of 38
OK thanks. Could you switch the base unit off at the plug and leave it off for 5 minutes then switch back on and retest
Message 32 of 38
Yes, caller display was working perfectly when I was with sky a few weeks ago. It hasn't worked since I moved over to talktalk.
Message 33 of 38
Just to confirm, are you using a cordless phone with the base unit connected to an electrical wall socket?
Message 34 of 38
No, still not working.
Message 35 of 38
Hi seajays,
I've made a change so could you please retest and let us know if caller display is now working
Message 36 of 38
Hi, yes, I've tried plugging the handset into the master socket, and even into the test socket behind the faceplate, but caller display isn't working.
Message 37 of 38
Hi Colin
Can I just check, have you tried the caller display handset directly at the test socket?
