Home Phone
Caller ID is still not working
userID
Message 33 of 33
Hello there,
I spoke to tech support last summer (2024) about this but its still borked and the Mrs is getting on at me about it again.
The story,
It worked fine (for years) until my neighbour opposite me had full fibre fitted (not sure of the provider) There was a OpenReach guy up our telegraph pole trying to sort out an issue with the neighbour's new connection. That is when the caller ID stopped working for us, it states on the handset "EXTERNAL" whenever the phone rings.
The OpenReach guy was back the next day, so I went outside and asked what he may have done, he said "Nothing to do with me mate". But its one hell of a coincidence isn't it? Incidentally, the plastic cover at the top of the pole has been off since then, the cover is dangling and in a bit of a breeze makes a really crappy wind-chime, all the wires and connections are exposed which can't be too good long term.
I spoke to tech support after this and they were helpful with ideas and tests etc, went through all the steps, even down to the test socket at the time but  nothing remedied it. Left it with them, then, a couple of days later, we got Caller ID back, for about half a day. Then nothing since.
I would have called back, but life happened and I kept not getting round to it. I'm hoping this route will help.
Cheers Marco
32 REPLIES 32
Message 21 of 33
Hi @userID
Thanks for your reply. Please let me know how you get on.
Are you logged into the Community every time you start to reply?
Message 22 of 33
Hi Debbie-I did do that before (last summer) But I haven't done it recently. I will test that tomorrow I hope and report back.
Quick side question, is it normal to have to get a verification code every time I want to reply to you guys questions?
Cheers
Message 23 of 33
Hi userID
Apologies for this.
Please can you confirm if you have tested with just the caller display phone directly at the test socket?
I can then pass this over to our Faults escalation team.
Message 24 of 33
Hi Chris, It's still not working I'm afraid.
It's still reporting incoming calls as simply "EXTERNAL"
Message 25 of 33
Hi userID,
Any luck?
Message 26 of 33
Hi Chris, I toggled it off for about an hour and then put it back on and it still wasn't working.
So then I decided to toggle it off for a full day (past 12am) and I have only just put put it back on. I will report back tomorrow how a longer on/off period worked, but I'm not hopeful, straws I be clutching!
Message 27 of 33
Hi userID,
How did you get on?
Message 28 of 33
Hi Chris, I did do that last Summer and I'll try again now. I've just turned it off. I'll give it a few hours and I'll turn it on again and check tomorrow during daylight hours.
Message 29 of 33
Hi userID,
Have you tried removing caller display from My Account and then re-adding it? If not then can you give this a try and let us know how you get on
userID
Message 30 of 33
Updated my profile,
Thanks for your quick response
Message 31 of 33
Hi userID
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Divsec
Message 32 of 33
Hi Marco your post has been escalated and you should hear soon.  In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Anonymous User
