Home Phone
Phone engaged
padunn
Message 40 of 40
My internet is working fine but my phone line does not have a dial tone, so I can't call out and when I try to call from my mobile it is permanently engaged.
I have logged a fault with support - but it says they cannot find a fault and I have been disconnected from the chat window.
Please help!
39 REPLIES 39
sabelo-TT
Message 1 of 40
Also, could you kindly confirm if you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line? For example a care alarm, lifeline, health pendant or fall detector.
sabelo-TT
Message 2 of 40
@padunn, thank you for informing us as we will continue on our end. Just to double check, besides the dial tone, are you able to make and receive calls from your landline?
Message 3 of 40
Sorry I have been away the last couple of days. I'm back home now and the phone is still engaged and no dial tone. Let me know what I can do to help.
Message 4 of 40
Thank you for getting back to us, we will need to run checks on your line, please confirm if you are at home to proceed.
Message 5 of 40
Yes that is correct, the phone is still permanently engaged.
Message 6 of 40
No worries, just to confirm are you still unable to make and receive calls? Thanks
Message 7 of 40
Hi, yes I am at home now. Sorry missed your reply this morning.
Message 8 of 40
I hope you are currently at home so we can continue. Thanks
Message 9 of 40
Hi there @padunn, these are just checks we have to go through. It's not that the handset is faulty, this is just part of diagnostics okay.
Message 10 of 40
Yes, the phone is connected properly. I think you are missing the original issue - the phone is permanently engaged - try calling my number. If the handset was faulty you would hear a ringing tone on the inbound call but the phone wouldn't ring.
It is still not working.
Message 11 of 40
Have you correctly connected the telephone cable to the telephone wall socket?
You will hear a click when inserting the telephone cable into the socket. Thanks
Message 12 of 40
Yes that’s correct. It is a BT cordless phone and the phone looks normal.
siphosethu-TT
Message 13 of 40
Ok so it's not showing no signal or searching, just the writing handset 1. This is just to confirm before I move forward. Thanks
Message 14 of 40
It just says Handset 1
Message 15 of 40
Can you take a look at the phones display, is it showing 'searching' or 'no signal'? Thanks
Message 16 of 40
Battery level is 100%
Message 17 of 40
1.Normal
2.Low
3.Flat
4.No Screen Display
Message 18 of 40
Can you check the battery level on your handset? It will look something like this. Thanks
Message 19 of 40
Thanks, I take it the base station is powered on.
Message 20 of 40
Powered via a separate plug. Power to base unit is ok.
