on 08-05-2025 08:41 PM
My internet is working fine but my phone line does not have a dial tone, so I can't call out and when I try to call from my mobile it is permanently engaged.
I have logged a fault with support - but it says they cannot find a fault and I have been disconnected from the chat window.
Please help!
on 09-05-2025 10:47 AM
Please can you confirm that the base station is powered on? Thanks
Will work with the cordless one okay. Thanks
on 09-05-2025 10:38 AM
Cordless, but have also tried a corded phone.
on 09-05-2025 10:33 AM
Thank you, which type of telephone do you currently have connected? Corded/Cordless
on 09-05-2025 10:28 AM
No cannot call out and if I try to call the line it is engaged.
Please confirm if you are able to make and receive calls? Thanks
on 09-05-2025 10:26 AM
Yes
09-05-2025 10:26 AM - edited 09-05-2025 10:26 AM
I'm guessing it's happening even now, correct? Thanks
on 09-05-2025 10:25 AM
Silence
on 09-05-2025 10:24 AM
Please describe what you can hear when you try to use the phone?
- Silence
- Noise on the line
- Intermittent Dial Tone
- Consistent Engaged Tone
on 09-05-2025 09:48 AM
Internet is working normally. I have tried unplugging the router and the phone line remains engaged. I have rebooted the router, and the internet reconnected ok.
on 09-05-2025 09:41 AM
I'm really sorry you have to go through such okay, I'll do my level best to have it fixed as soon as possible. 😇
on 09-05-2025 09:40 AM
Thank you for confirming that for me, are you having issues with your internet/broadband? Thanks
on 09-05-2025 09:36 AM
No. The only things connected is my phone and the broadband.
on 09-05-2025 09:20 AM
Do you have any active monitoring for life threatening health reasons which is solely dependent upon your TalkTalk Broadband or Telephone line?
For example, a care alarm, lifeline, health pendant or fall detector. Thanks
on 09-05-2025 09:08 AM
I have tried with a new handset and the result is the same. It is not full fibre, it is a BT socket which incorporates both a phone connection and a connection for the broadband, so there is not an external microfilter.
on 09-05-2025 09:06 AM
Yes I am at home this morning
on 09-05-2025 08:25 AM
Hi there @padunn, please confirm if you are currently at home should we need to run checks on this. Thanks
on 09-05-2025 07:26 AM
@padunn, your post is in the queue for attention.
It's worth seeing if you can test with another handset in case there's anything wrong with the actual phone.
Sometimes there can be a fault with the microfilter and it's also worth plugging in directly at the test socket.
Is this FTTC or have you actually got Full Fibre, so this then would be a VOIP problem? Helpful to know which package you are on.
