Home Phone
Caller display
Shirltay1
Message 27 of 27
My home phone Caller display has suddenly started to show ALL incoming calls as Withheld. I have been in touch with Talk Talk chat and they say line is ok and sent me an email with suggestions to check, which I have done and still not working. Getting frustrated now as I don’t normally answer withheld numbers. Any suggestions please
26 REPLIES 26
Message 1 of 27
Sorry, not yet, I'll let you know when I have any more information
Message 2 of 27
Do you have an update on this issue yet?
Message 3 of 27
OK thanks. I'll pass this over to our network team as it's not letting me do anything, it doesn't actually look as though it was removed. I'll let you know when I receive an update
Message 4 of 27
Can I have an update on this please. Still showing incoming calls as Withheld.
Message 5 of 27
OK, have a great weekend 🙂
Message 6 of 27
  • Ok, fingers crossed then for Monday!
Message 7 of 27
Hi Shirltay1,
The system isn't allowing me to re-add yet it so I'll try to re-add it again on Monday, apologies for any inconvenience
Message 8 of 27
I've removed it, I'll add again in an hour. I'll let you know when I've done it
Message 9 of 27
OK thanks. I'll remove it now
Message 10 of 27
Ah , ok sorry. Have tried again but still Withheld.
Message 11 of 27
I don't need you to switch the internet off, just need you to call your landline to see if the number is still showing withheld
Message 12 of 27
Rather than me wasting more time without the internet by switching it off, can you please remove it and then re add . I would also like to know why when I try to  remove phone boosts they still remain active .
Message 13 of 27
OK thanks for trying. Everything looks OK from our side now. Could you just test one more time and if it's still not working I'll try removing it and re-adding it
Message 14 of 27
Ok, switched off for 90 mins and still not working. Incoming call still showing as Witheld.
Message 15 of 27
OK thanks. Could you switch the ONT and router off and leave  them off for at least 30 minutes, then switch back on and retest. Please let us know once you've done this
Message 16 of 27
Yes phone plugs into router
Message 17 of 27
OK, that sounds like the Sagemcom wifi hub, so your telephone plugs directly into your router?
Message 18 of 27
The only label is the TalkTalk WiFi net work I’d answer password label . The router is Black and has a white light
Message 19 of 27
There should be a label on the back with the manufacturers name and model number
Message 20 of 27
How do I tell what router I have?
