Home Phone
Cost of 0345 numbers
brabo
Message 6 of 6
What are the costs for dialing 0345 numbers?
What?
5 REPLIES 5
Message 1 of 6
To confirm with the boost calls are free for up to 60 mins.
Message 2 of 6
You are fine for up to one hour at a time using the Unlimited Calls UK boost, @brabo, for 01, 02 and 03 numbers and normal mobile phone numbers.
You can end the call and dial again as soon as you like to keep the calls within an hour each time.
Going over gets expensive very quickly, 24p per minute.
Message 3 of 6
Thank you, Christ-TalkTalk,
Yes this is using my landline.
This is my tarif:
My telephone
Unlimited UK Calls Boost
£16.00
International Max Calls Boost
£14.00
What?
Gliwmaeden2
Message 4 of 6
Normal 24p per minute unless you have the UK calls boost and unless you are calling Talktalk support from your Talktalk line, @brabo.
Chris-TalkTalk
Message 5 of 6
Hi brabo,
Is that calling from your TalkTalk landline?
